3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? #995117
05/18/11 08:24 PM
05/18/11 08:24 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I finally got my 3" exhaust welded up with turndowns before the axle. Too loud for me and I am contemplating running 2 1/2" tailpipes as space is limited on my 67 Coronet; not much room between the springs and gas tanks on this year of B bodies. Anyone running this combo? My motor is a 512 for the street mostly. Thanks
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995118
05/18/11 08:30 PM
05/18/11 08:30 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
By the time the exhaust gases get to tail pipes, they've cooled and condensed enough that the reduction in pipe size is harmless. In fact, it could arguably improve scavenging since velocity will be higher through the smaller pipes.
Should also quiet it down a bit.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: 471Magnum] #995119
05/18/11 08:35 PM
05/18/11 08:35 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Thanks a bunch; that's what I wanted to hear and it will make matters a little easier on the installation....
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995120
05/18/11 10:02 PM
05/18/11 10:02 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Couple of years ago, a friend of mine used to have a pretty wild 66 Satellite with a cross-rammed Hemi. He had 3.5" exhaust with little single chamber Flowmasters and turn downs. But sometimes he would run tailpipes. They were also 3.5" and went over the axle and dumped right behind the tires. Sort of like a old Chevy Nova. It was still pretty loud.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: 471Magnum] #995121
05/18/11 10:07 PM
05/18/11 10:07 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
But back in the mid/late 90s when Car Craft Magazine had their project Chevelle, they did an extensive test of exhaust systems on the car. The car did make a little more hp on the chassis dyno without tailpipes.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995122
05/18/11 10:16 PM
05/18/11 10:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why not just get different mufflers????
Coming soon!!!!
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995123
05/18/11 10:17 PM
05/18/11 10:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
whoops sorry yeah any 1/2 system is going to be loud. just get some tail pipes. Don't understnad how people can have a street car with no tail pipes..super annnnoooying
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Mr.Yuck] #995124
05/19/11 01:12 PM
05/19/11 01:12 PM
Pittsburgh, Pa
Jeff_383 Online content
Jeff_383  Online Content
Pittsburgh, Pa
I have a 67 coronet with 3" headpipes and TTI 2.5" tailpipes. Works good and fits easy.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Jeff_383] #995125
05/19/11 04:09 PM
05/19/11 04:09 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I agree you should have a full exhaust in a street car. With c-boies there is room for only one pipe past the gas tank, so the cure is run the pipes under the frame rails. Real common and looks right. So you could use the 3" if you want. I beleive that the smaller pipes would help as mentioned above. Not sure of application but big pipes are not needed unless you are pushing seriuos Horse Power at high R.P.M.s. Just one old guys opinion.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Jeff_383] #995126
05/24/11 05:22 PM
05/24/11 05:22 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I have a 67 Coronet with TTI headers and 3" exhaust to the bumper. tight fit, but it does work with no clearance issues.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995127
05/24/11 05:50 PM
05/24/11 05:50 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Here are a few pics of the custom exhaust on my '80 Diplomat coupe project car. This is a 3" pipe, all the way, going through some Hooker MaxFlow mufflers:
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995128
05/25/11 03:08 PM
05/25/11 03:08 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
I've the same set up as Jeff 383 in my 67 GTX. 3" from headers to mufflers; 2.5" from mufflers to back bumpers. Fit nicely w/ no clearance issues by gas tank or rear springs.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995129
05/25/11 05:29 PM
05/25/11 05:29 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
did the exact same thing on My old coronet and My recent satellite...2 inch hooker headers into 3 inch pipes w/flowmasters and reduced to 2 1/2 just before the rear axel...took alot of low rpm hum out..sounds great..many have complimented "that is how all mopars should sound"...
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: terzmo] #995130
05/26/11 05:56 PM
05/26/11 05:56 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Sounds great guys; I have a set of 2 1/2" tailpipes on the way, should have them installed by next week. Again thanks for your input; I am tired of the low speed humming and resonance with the way I have it now.
Re: 3" exhaust with 2 1/2" Tailpipes??? 66/67 B Bodies or?? [Re: Hemi_Ram] #995131
05/26/11 09:28 PM
05/26/11 09:28 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
just my recent experience with exhaust...
my 5.2L dakota has a single exhaust pipe going back due to the gas tank hanging inside the frame rails, infront of the axle. I used a 3" system, 2 of the long 3" powerstick mufflers welded together. 60" total length, turn down/dump right before the rear axle. sounded great especially at WOT. I'd say it made the truck sound like a 12 second truck since it's got a nice cam to it.
but, on long trips, it was driving me nuts. I actually broke down and put ear plugs in because the resonance was so loud and droning inside the cab.
but...I like the clean look of no tail pipes hanging out.
I had a little more room under there, so I welded a 12" x 3" single chamber glass pack muffler on it, and then took the exhaust up and over the axle, where it now points down and to the rear next to the spare tire, slightly out to the side, away from it.
at idle, it sounds about the same, and it's still pretty loud at WOT with that "high hp crackle" I was looking for...although it is quieter at WOT now.
but, the biggest gain to me was at part throttle cruise. now it's MUCH quieter at cruise, no more drone or resonance. I will now have no qualms about putting my 5 year old in it for a 6 hour trip to Carlisle in several weeks.
maybe instead of stepping down to a 2.5" you can keep it a 3" and add another small glass pack muffler/resonator to the end of it, and still have it dump under the car somewhere for the clean "no-tail pipe" look
**Photobucket sucks**
