Which SB water pump should I use? (pictures)
#994986
05/18/11 05:30 PM
05/18/11 05:30 PM
Posts: 3,877 Oregon
hooziewhatsit
Long story short, I figured I needed to change my waterpump as I didn't think the old one was moving water very effectively, as I've always had cooling issues, even with a new radiator, and now the mercedes fan.
I just got the old one out, and as you can see in the pictures below, I think it may be the better choice. There is less clearance between the vanes and the front of the pump, and less clearance to the timing cover than the new pump. Both pumps have 8 vanes.
My pulley measures ~7" diameter to the outside edges. How big is the small pulley? I should probably head to the junkyard to see of I can find one. I rarely go over 3500 rpms, so I don't think high RPM cavitation will be an issue.
Sooo, what say ye moparts? New pump? Old pump? Old pump & smaller pulley?
To throw a wrench in the whole process, I plan to replace this engine with a magnum 360 hopefully this summer, so I didn't want to drop $100 on a new water pump.
Thanks for the thoughts.
First, the old pump:
Re: Which SB water pump should I use? (pictures)
[Re: hooziewhatsit]
#994988
05/18/11 05:42 PM
05/18/11 05:42 PM
Posts: 15,487 Florida
scratchnfotraction
IMHO,use the new pump you can see where the vanes on the old pump are rubbing on the pump housing I bet that if before you removed it with fan and pully in place you could move the shft by hand..the bearings and seal are on the way out when it does that. the 6 vane pump goes with a small a/c pully the 8 vane pump goes with the larger non a/c pully 6 vane spins faster to move x amount of water at idle 8 vane spins slower to move same x amount of water at idle small pully on a 8 vane pump can cause it to cavitate at sustained high rpm you can use a HD thermoclutch and a 7 blade fan for max cooling on either combo,but need to be the right ratio on the pullys
[Re: Andrewh]
#994990
05/18/11 06:22 PM
05/18/11 06:22 PM
Posts: 3,877 Oregon
hooziewhatsit
The lower hose has a spring in it, so it shouldn't be sucking closed. I just put the old pump in my vice, and can now feel just a tiny bit of play in the shaft. Soo, new pump it is. I did have a 7 blade fixed fan on it, and now have the electric mercedes fan. At idle with both set ups, it will maintain itself, but wouldn't actively and quickly cool itself off. Quote:
On the highway it usually runs around 2700 rpm. It's had a couple 4k romps, but few and far between. I wouldn't think that would be high enough to cause cavitation? This is a work truck, so it rarely sees anything a drag car would consider normal. It's also old and tired, and I don't want to blow it up
[Re: hooziewhatsit]
#994991
05/18/11 08:23 PM
05/18/11 08:23 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Pull your plugs. Make sure it's not a head gasket issue. That was the problem I had with the hot rod. You can usually find it by a loss of coolant. My lower hose was being sucked flat at a bend where I couldn't feel it. If your hose has a good spring in it that should not be your problem. There's always the thermostat and radiator to look at.
Since your pump is out pull the block drains and flush the block through the water pump holes. That will make sure you don't have a heavy layer of ickies in the block. I also had that problem but never knew it because the coolant wasn't nasty looking. The sediment simply didn't get stirred up.
[Re: RapidRobert]
#994993
05/18/11 09:56 PM
05/18/11 09:56 PM
scratchnfotraction
what say ye moparts? Old pump & smaller pulley?
That. Minor scraping wont hurt you & if you have the right puller pull it back a hair
minor...thats what you say when you are broke down cause the impeler eat away at the pump then eat away at the t-cover to dump coolent into the oil pan
last one cost me a new fan/clutch/rad..all it had was a slight wobble i could feel by hand with the belt off.
last t-cover I did on an inboard with a bad wp, had a groove cut so bad it leaked into the oil case,but it was from a large 8" piece of lower rad hose spring wraped around the impeller
even heard say that it can cost a hood too!
[Re: hooziewhatsit]
#994996
05/20/11 10:13 PM
05/20/11 10:13 PM
Posts: 3,877 Oregon
hooziewhatsit
got the new pump tested today. If anything, it's a little worse than the old one At 205*, I watched two little bubbles sit on the coolant in the radiator, even after I revved it up. I presume I should see more flow than that? I think this is the crux of my issues. I got a (slightly) smaller diameter pulley from the junkyard, so I'll put that on later. The radiator however, IS dropping temperature pretty well. I can hardly touch the top hose while the bottom hose is nice and cool.
[Re: hooziewhatsit]
#994997
05/20/11 11:04 PM
05/20/11 11:04 PM
RapidRobert
No way the new 8 blade pump in the 2nd pic w the smaller vanes is going to cool as good as the 8 blade larger vane pump. Is the temp you get at an extended idle at a stoplight w the changes a # you can live w? May be another issue, crud accum in block/heads/slight vac leak/timing or ?. Sounds like it's liveable till th eng ch but it'd b a feather in your cap to correctly diagnose/solve what's behind it.
[Re: RapidRobert]
#994998
05/20/11 11:30 PM
05/20/11 11:30 PM
Posts: 3,877 Oregon
hooziewhatsit
It seems to like to stay around 210*F with the old and new pump and with the mercedes fan at full speed. This temp is fine with me, although its only going to get warmer out now that summer is here. I redid the top end of the engine a couple (3 now?) summers ago, and at that time knocked the freeze plugs out and removed the gunk in the bottom of the block. Heads were hot tanked and rebuilt. New radiator about the same time. I agree I'd like to figure it out, but at this point... And I just discovered the smaller pulley won't fit. If I didn't have to remove the fan to get it on, it would run in to the crank pulley. Ohwell In a properly working set up, should I be able to see lots of liquid moving in the top tank of the radiator?
[Re: hooziewhatsit]
#995000
05/20/11 11:58 PM
05/20/11 11:58 PM
feets
Senior Management
Senior Management
Irving, TX
You should see lots of movement inside the radiator once the t-stat opens. If that's not happening the these things:
1) Remove the hose from the thermostat housing and look inside. Is the thermostat pointy side up? If it's upside down (spring end up) it could restrict the water flow.
2) Pop off the upper hose and start the engine. Make sure the radiator has water in it higher than the water pump. Does water come out once the engine reaches temperature? If not, there's some sort of restriction in the engine's cooling passages such as the thermostat not opening.
3) Pull the spark plugs. Are any of them cleaner than the others? If so, you probably have a head gasket that is allowing exhaust to pass into the cooling system. You usually see bubbles in the coolant when that happens.
Let us know what you find with these things and we can take it from there.
[Re: feets]
#995001
05/21/11 12:59 AM
05/21/11 12:59 AM
Posts: 3,877 Oregon
hooziewhatsit
There was enough light left so I went ahead and pulled the thermostat just now. WOW, so that's what it looks like when the water is moving Project for tonight: boil both thermostats, and watch them not open I pulled the front 4 plugs a couple nights ago. Actually looked pretty good; just a tinge of brown on them. The back couple are a PITA to get to
[Re: hooziewhatsit]
#995002
05/21/11 02:22 AM
05/21/11 02:22 AM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
i run 160's in mine, and i drill a small 1/8" hole into the stat, so it wont develop an "airlock" in it. i also block off the bypass from the inside of the stat housing, filling up the nipple with plastic steel, and smoothing it into the top of the manifold at the nipple. this directs ALL the water moving through the pump, into the radiator. the IR gun shows, it works. sounds like you have a bad stat, or two. you can run without it, if needed. or, make a solid gasket out of cork, and pop a hole in the center, the size of a quarter. it will restrict the water a bit, and warm it up a bit faster. i like the 160, as once the engine warms up, it pretty much just stays open, no cycling open and shut.
[Re: Golden-Arm]
#995003
05/21/11 02:51 AM
05/21/11 02:51 AM
Posts: 3,877 Oregon
hooziewhatsit
I boiled both thermostats and they technically open. It opened maybe a 1/16", and once back in the air the promptly shut again. IMO, 160 is too cold. I'd like to have heat in the winter I wonder if just restricting the bypass would gain any benefit...
[Re: hooziewhatsit]
#995004
05/21/11 10:14 AM
05/21/11 10:14 AM
feets
Senior Management
Senior Management
Irving, TX
There's the issue.
Drop a GOOD t-stat in the truck and hit the road. I usually run a 180 or 190 all year.
