Crank Trigger
#994557
05/17/11 10:40 PM
05/17/11 10:40 PM
Posts: 388 Michigan
SD800
Guys, Just installed a crank trigger on the 572 in my challenger. We set initial timing at 34 degrees advanced and fired it up.it idles at 1100 rpm at 34 degrees but when you whack the throttle the timing will retard by 10 degrees. I know there is some loss of timing with the timing chain and gears between the distributor gear but I never realized it wAs this much. Is this normal with a crank trigger and is there a way to compensate for this?
You'll have plenty of time to sleep when your dead, let's go
Re: Crank Trigger
[Re: '72CudaRacer]
#994560
05/17/11 10:53 PM
05/17/11 10:53 PM
Posts: 388 Michigan
SD800
Yes the distributor is locked out
Re: Crank Trigger
[Re: SD800]
#994561
05/17/11 10:59 PM
05/17/11 10:59 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Not sure what that is, should be rock solid, no movement at all. One thing to try is the polarity could be wrong on the pickup. That will usually cause it it be off because of a leading edge/trailing edge thing but it still should not move
Re: Crank Trigger
[Re: SD800]
#994564
05/17/11 11:01 PM
05/17/11 11:01 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
What is the rest of the ignition system?
Re: Crank Trigger
[Re: SD800]
#994565
05/17/11 11:08 PM
05/17/11 11:08 PM
Posts: 388 Michigan
SD800
Does it matter which way the wheel is installed,in order for the wheel to center on the balancer we had to install the wheel with the rotation arrow against the balancer
Re: Crank Trigger
[Re: SD800]
#994567
05/17/11 11:25 PM
05/17/11 11:25 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
What's the gap? Good call on timing not moving with dizzy unlocked. I was tired I'm a little confused on this one now with the parts u listed. You should be up and running. Try to swap the wheel. It's got an arrow for a reason I guess.
Re: Crank Trigger
[Re: SD800]
#994569
05/17/11 11:39 PM
05/17/11 11:39 PM
Al_Alguire
Las Vegas
Does the timing stabilize at a higher RPM?
Re: Crank Trigger
[Re: SD800]
#994571
05/18/11 02:18 AM
05/18/11 02:18 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
What brand timing light?? Borrow another light, and hook it to a battery not running the car, and confirm reading.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: Crank Trigger
[Re: SD800]
#994572
05/18/11 02:20 AM
05/18/11 02:20 AM
Posts: 176 Down under
slantman
Down under
I'm pretty sure the rotation arrow has to be facing out, away from the balancer. Otherwise the polarity of the flying magnets is the wrong way round. The engine will still run, but not make power as it revs up.
Re: Crank Trigger
[Re: SD800]
#994573
05/18/11 02:22 AM
05/18/11 02:22 AM
Al_Alguire
Las Vegas
What Billy said is an excellent point. Before panic sets in might be a good idea to "get a second opinion".
Cant think of any logical reason to see what you are seeing. is the Moroso pickup wire shielded? Is the pickup wiring running near anything else electrical, particularly the water pump? Sometimes you can get some unwanted RF that will cause all sorts of crazy things to happen.
I missed the part about the arrow. Would definitely want it installed correctly with rotation. I assume they put them that way for a reason?
Re: Crank Trigger
[Re: EchoSixMike]
#994575
05/18/11 09:40 AM
05/18/11 09:40 AM
Posts: 388 Michigan
SD800
Sounds like that may be my issue.
Thanks for the help guys
