Small Block Lean Burn distributor? #994194
05/17/11 12:48 PM
05/17/11 12:48 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I have these 2 NOS small block distributors.
What do I have? Is the one with the single wire OK and useable in a high performance application? I assume this is basically the same as what MP sells.
What about the one with the dual wire? Is it a lean burn distributor? Is it useable in a hight performace applicatrion or is it junk? Can parts be swapped to work like a regular electronic distributor?
Re: Small Block Lean Burn distributor? [Re: domingo] #994195
05/17/11 12:49 PM
05/17/11 12:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
pic 1
Re: Small Block Lean Burn distributor? [Re: domingo] #994196
05/17/11 12:50 PM
05/17/11 12:50 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
pic 2, note the dual wires.
Re: Small Block Lean Burn distributor? [Re: domingo] #994197
05/17/11 02:49 PM
05/17/11 02:49 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
lean burns, at least the 80's incarnation on M bodies, don't have mechanical or vacuum advance in them...
2017 Grand Cherokee Overland
Re: Small Block Lean Burn distributor? [Re: patrick] #994198
05/17/11 05:07 PM
05/17/11 05:07 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Yep, those are both LeanBurn units with a VR sensor for electronic ignition. The 2nd one has 2 VR sensors in it.
I have heard conflicting info that:
the dual units were used in copcar applications, or in the later LeanBurn applications that also had fuel control via a feedback carb. (In those apps 1 sensor was used durign starting, teh 2nd one for after hte engine was running).
Or either statement could be true.
Re: Small Block Lean Burn distributor? [Re: Fury Fan] #994199
05/17/11 08:38 PM
05/17/11 08:38 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
So they both are lean burn units?
How do you spot them?
Re: Small Block Lean Burn distributor? [Re: domingo] #994200
05/17/11 09:17 PM
05/17/11 09:17 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
No mechanical or vacuum advance is the clue.
Re: Small Block Lean Burn distributor? [Re: domingo] #994201
05/17/11 09:18 PM
05/17/11 09:18 PM
no vac adv pod EDIT 2 pairs of leads for the dual pickup ones
Re: Small Block Lean Burn distributor? [Re: FuryUs] #994202
05/18/11 09:20 AM
05/18/11 09:20 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
And make sure the vacuum pot hasn't simply been removed, in which case the dizzy will have an open slot where the pot mounted.
Re: Small Block Lean Burn distributor? [Re: Fury Fan] #994203
05/28/11 12:16 PM
05/28/11 12:16 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I chekced my distributors again, and they both have the provisions on the case for the vaccumm advance. They have just been removed...
So based on this, they would not be lean burn units....
So, what are they?
Re: Small Block Lean Burn distributor? [Re: domingo] #994204
05/28/11 12:50 PM
05/28/11 12:50 PM
Pretty sure you could use either in a perf app & for sure the single pickup one. You'd just ignore the dual pickup & open it's gap to get it out of the way then gap the other one to .006-.008" at the tightest tooth. Finalize your initial then use that figure to shorten the slots to get 35 total (vac adv unhooked if you are going to add the pod to the dist). You would want to toss the heavy spring w the long loop & sub in another which will take some experimentation to get the right curve then hookup the vac adv & work w it. If the pickups ain't exactly opposite pick the one that will give you the best rotor phasing (location)
Re: Small Block Lean Burn distributor? [Re: RapidRobert] #994205
05/28/11 01:11 PM
05/28/11 01:11 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
From what I remember reading about that system, one pickup was for START and one was RUN. I don't remember the difference in timing between them. I've thought about trying to use one with an MSD with locked timing and put a switch to toggle between START and RUN. Not too sure if it would work. One of those backburner projects.
Floyd Lippencott IV
