09 Jeep Patriot Leaking Sunroof #994087
05/17/11 01:24 AM
05/17/11 01:24 AM
Westchester County NY
Big Mopar Jay Offline OP
A very good friend of mine has a 09 Jeep Patriot. Every time it rains she has water dripping from the dome light. This is the fourth time she has had it back at the dealer. The Last time in they replaced the seals and the drain assembly. Any techs out there know what the deal is with these sunroofs? Seems to be a common problem with the 09 Jeep Patriots. Any info will help.
Mopar Nation 70 Challenger SE 340 71 Challenger 2nd registered owner
Re: 09 Jeep Patriot Leaking Sunroof [Re: Big Mopar Jay] #994088
05/17/11 07:01 AM
05/17/11 07:01 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Those are miserable water leaking cars have seen alot of different areas they leak from. For starters remove the headliner and be careful if it has airbags. Check the rear drain tubes (often get overlooked) for being plugged of pinched. There is a TSB for that. The front corners of the sunroof frame. Add strip calking to the seams where the frames come together. The most recent one was leaking under the roof rails for the luggage rack. The body seams not sealed in spots.
See attachment for the TSB. Very good information.
6637338-waterleak.pdf (675 downloads)
Re: 09 Jeep Patriot Leaking Sunroof [Re: Big Mopar Jay] #994089
05/17/11 08:30 AM
05/17/11 08:30 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
shouldn't it be under warrenty?
Coming soon!!!!
Re: 09 Jeep Patriot Leaking Sunroof [Re: Mr.Yuck] #994090
05/17/11 08:32 AM
05/17/11 08:32 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Not if its got over 36K on it.
Re: 09 Jeep Patriot Leaking Sunroof [Re: Todd] #994091
05/17/11 10:10 AM
05/17/11 10:10 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If it's been in four times for it chances are it was in while warranty covered it... I'd be talking to a service manager & if he won't cover it I'd be asking to speak to the zone rep..
Re: 09 Jeep Patriot Leaking Sunroof [Re: Big Mopar Jay] #994092
05/17/11 07:26 PM
05/17/11 07:26 PM
Pittsfield, Mass.
Russ_Davis Offline
Russ_Davis  Offline
Pittsfield, Mass.
Just had my 2010 Compass fixed same problem. The pass side drain tube was kinked from the factory. They told me they were aware of it and won't recall them because it not a safety issue. But will fix them if needed.
Re: 09 Jeep Patriot Leaking Sunroof [Re: Russ_Davis] #994093
05/18/11 04:13 AM
05/18/11 04:13 AM
Thanks for the info Todd. The Jeep has just under 28K on it. I'd have to look at her receipts from the dealer to see if the work from that TSB was done. I know the last time it was in for the same issue, they had to order all the parts. They had the Jeep for 4 days to do the work. The next would be to talk to the Zone rep. We are supposed to get a lot of rain here in the next week so we'll see if the problem is take care of. Thanks for the info guys.
Re: 09 Jeep Patriot Leaking Sunroof [Re: Big Mopar Jay] #994094
03/02/12 04:02 PM
03/02/12 04:02 PM
NY
commander1 Offline
commander1  Offline
NY
I have the same problem with my Jeep commander. Water leaks onto my driver's side floor board. The Chrysler service department tells me that it is because the sunroof drain tubes are clogged. And they insist every time (4 times so far) that it is my responsibility to keep the sunroof clear of debris and therefore, I have to pay to have the tubes cleaned out every time. And Chrysler Corp refuses to take responsibility. Anyone know who manufactures the sunroofs for Chrysler?
Re: 09 Jeep Patriot Leaking Sunroof [Re: commander1] #994095
04/07/12 11:11 PM
04/07/12 11:11 PM
New Jersey
sunroofleak Offline
sunroofleak  Offline
New Jersey
We recently brought a class action in New Jersey because of the sunroof leaks. It is a serious problem. if you bought a chrysler / jeep after June 10, 2009, contacts us at info@pllawfirm.com
Re: 09 Jeep Patriot Leaking Sunroof [Re: Russ_Davis] #994096
04/07/12 11:13 PM
04/07/12 11:13 PM
New Jersey
sunroofleak Offline
sunroofleak  Offline
New Jersey
it certainly is a safety issue - mold, electrical shorts just to name a few . . . it is for this reason we brought a class action - www.pllawfirm.com.
Re: 09 Jeep Patriot Leaking Sunroof [Re: sunroofleak] #994097
04/08/12 08:54 AM
04/08/12 08:54 AM
places
79powerwagon Offline
places
It is? It probably has nothing to do with billable hours, does it?
