Best way to re-dye in black a Plymouth lower dash pad #993527
05/16/11 11:12 AM
05/16/11 11:12 AM
FL, Miami
rikhemi Offline OP
rikhemi  Offline OP
FL, Miami
I'm searching for the best way to re-dye the lower dash pad for my 68 Plymouth GTX.
Re: Best way to re-dye in black a Plymouth lower dash pad [Re: rikhemi] #993528
05/16/11 11:21 AM
05/16/11 11:21 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I've used Herb's interior paint with good results
http://www.herbsparts.com/proddetail.asp?prod=PAINT
Re: Best way to re-dye in black a Plymouth lower dash pad [Re: rikhemi] #993529
05/16/11 11:27 AM
05/16/11 11:27 AM
canada
jneuf Offline
jneuf  Offline
canada
I sprayed my dash pad with SEM Color Coat. Followed all the directions to prep it properly, and it seems to be holding up fairly well. There is one ding in it that was my fault when I re-installled the dash, other than that, I'm happy with it.
Re: Best way to re-dye in black a Plymouth lower dash pad [Re: rikhemi] #993530
05/16/11 11:39 AM
05/16/11 11:39 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
