Bring your Alternator Pictures! #993195
05/15/11 09:35 PM
05/15/11 09:35 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
I have a "leaning in" 'bent' Alternator, you can see its out of line with flywheel.. this car had a A/c in it, but was ripped out, my question is , what hardware is used and what am I missing to stiffen this up? you can see from pic Im using a 3 hole triangle plate, with top hole for A/c un used. and a long shank and shalf through the front of alternator, with nothing holding the front causeing the lean, is this how the other Challengers are, everyone's lean?
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Bring your Alternator Pictures! [Re: Caparco] #993196
05/15/11 11:08 PM
05/15/11 11:08 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
The triangle bracket is in the wrong place. It is supposed to attach to the two water pump bolts and the unused hole in your pic attached at the front of the alternator.
Here is a pic the (not correct it is a mock up of a bracket for a GM alternator) but gives an idea of how the bracket should be attached to the water pump. On your car it will line up with one of the holes at the top of the head, not the lower hole shown here.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Bring your Alternator Pictures! [Re: finadk] #993197
05/15/11 11:58 PM
05/15/11 11:58 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Hmm then where does the slide bracket to adjust belt at the bottom of the alternator go.. yours don't show
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Bring your Alternator Pictures! [Re: finadk] #993198
05/16/11 12:01 AM
05/16/11 12:01 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
74 318 valiant
73 400 Charger
Re: Bring your Alternator Pictures! [Re: bordin34] #993199
05/16/11 09:52 AM
05/16/11 09:52 AM
Hampden, Maine
Procommuter Offline
super street
Procommuter  Offline
super street
Hampden, Maine
73 cuda
Wes 73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
Re: Bring your Alternator Pictures! [Re: Procommuter] #993200
05/16/11 09:56 AM
05/16/11 09:56 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
exploded view
Re: Bring your Alternator Pictures! [Re: Caparco] #993201
05/16/11 07:00 PM
05/16/11 07:00 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
Powermaster on a small block...
TIP: Cover those unsightly spacer tubes with shrink-tubing. They'll look nice for a long time.
`68 Barracuda 340-S
Re: Bring your Alternator Pictures! [Re: Caparco] #993202
05/16/11 07:11 PM
05/16/11 07:11 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That triangular bracket needs to be on the FRONT of the alternator. The hole that is currently open is for the long bolt that goes through the alternator. the other two holes mount on the water pump bolts (one of them is doubled with the adjustment bracket).
Just my
Re: Bring your Alternator Pictures! [Re: roadhazard] #993203
05/16/11 07:48 PM
05/16/11 07:48 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Great response guys thanks for the help, extra thanks to you gtx6970, I see now that I got it all messed up, and am missing the smaller spacer, to fix this.Just got to find one or at least how long they are.
Thanks again all
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Bring your Alternator Pictures! [Re: Caparco] #993204
05/16/11 08:02 PM
05/16/11 08:02 PM
ohio
geol Offline
geol  Offline
ohio
old picture of 69 340
Re: Bring your Alternator Pictures! [Re: geol] #993205
05/17/11 02:02 AM
05/17/11 02:02 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From Year One
Re: Bring your Alternator Pictures! [Re: Caparco] #993206
05/17/11 09:52 AM
05/17/11 09:52 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You need to think big...
Re: Bring your Alternator Pictures! [Re: Snoopy] #993207
05/25/11 04:21 PM
05/25/11 04:21 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
I actually have a 3 holes on the right and one on the left, with my bracket, and no where does it hook up with the front of it to the water pump, holes don't match up, I ordered the 3 hole bracket,Hopeing it fits, wish I could still see the top bracket hooked up better and close up, where does the small spacer go, and does that looong bolt go in the single hole of triangle bracket then through the alternator then into the head or just ends with a nut, also the bottom bracket I have is shaped like a Y 2 on the engine and one slide (tight) adjuster to the alternator, not a single peice
Any more help, Im confused
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Bring your Alternator Pictures! [Re: Caparco] #993208
05/25/11 05:12 PM
05/25/11 05:12 PM
scratchnfotraction Offline
what I see is you have the alt/A/C brracket from the back of the a/c comp that has the alt pivot hole
you will need to use the front a/c comp bracket that has the front pivot hole and goes across the top front of the water pump to capture the top middle wp bolt behind it...a/c brackets with out comp mounted up in stock locations
this will give the correct spaceing on the alt pivot bolt and keep it in the stock location
i cant tell if you have the a/c or non a/c pulleys if so you need the non a/c alt brackets like in the explode pic of them that was posted
the grooves look off as you only have 1 belt on the front alt groove of the double groove alt
with the a/c bracket the slide adjuster arm will bolt on the lower wp bolt and swing up to alt
with the non a/c alt brackets the swing arm bolts on the lower wp bolt along with the tri angle piece
alt bracket depends on pulleys used
removeing the a/c comp and use just the brackets is fine with the a/c pullys
you can also just remove the support rib on the neck of the wp,file smooth and run 2 short belts right off the crank to alt and leave the a/c comp and brackets in place as well.
Re: Bring your Alternator Pictures! [Re: Caparco] #993209
05/25/11 05:24 PM
05/25/11 05:24 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
That's a joke... Right?
sorry
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993210
05/25/11 05:24 PM
05/25/11 05:24 PM
hooziewhatsit Offline
Just so it's clear, I made a picture
Move the bracket to the front, and line up the holes as colored:
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993211
05/25/11 05:25 PM
05/25/11 05:25 PM
ok looking at the pic some more..
i think you have the a/c pulleys
you have the 1 alt belt straight down to the crank and the ps and wp run on a belt
you just need the front alt-a/c bracket to support the alt pivot bolt
that will line the belt up straight
look at the belt you have on the front groove of alt to the crank...see the rib on the neck of the wp that wont let you run another belt in the rear groove from alt to crank
thats the piece you want to remove and file flat and run 2 belts on the alt
other option is get non a/c pullys and alt brackets(like in all the pics posted) with correct belts and a single groove alt pully
the other thing to remember with the pully ratio is the a/c wp use the smaller pully and 6 vane wp
the non a/c pulleys use a larger pully and 8 vane pumps
not good to mix match the pully ratio and wp vane count either on high rpm engines,it can cavitate at the wp vanes.
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993212
05/25/11 05:29 PM
05/25/11 05:29 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Here is a decent picture showing how it should be. I did a simple image search on Google.
Re: Bring your Alternator Pictures! [Re: scratchnfotraction] #993213
05/25/11 05:30 PM
05/25/11 05:30 PM
the 3 hole y lower alt bracket is a a/c lower alt bracket
it will be used with the rest of the a/c brackets
the othe flat swing arm is for non a/c set up
cant strees it enuff..dont mix match the stock a/c or non a/c brackets and pullys
you just need that 1 a/c front bracket and 1 more belt for the alt and crank to be set up good to go
every one is correct showing you the non a/c brackets/pullys and the way it mounts...but you have 2 of the 3 a/c brackets and they are not the same and wont fit any other way.
Re: Bring your Alternator Pictures! [Re: pinkduster] #993214
05/25/11 05:34 PM
05/25/11 05:34 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Another:
