318 Truck Pan?? #992613
05/15/11 08:30 AM
05/15/11 08:30 AM
On the south side of Nowhere
S/ST 3040 Offline OP
I tried this post in the truck section............
I think I'm looking for an oil pan off of a 318 truck/Dakota.
I need a rear sump pan but, need measurements from the
pan rail to the bottom of the pan. (front and rear)
Can anybody help??
Thanks in advance.
Re: 318 Truck Pan?? [Re: S/ST 3040] #992614
05/15/11 09:50 AM
05/15/11 09:50 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I can later, got to go out for a while. Got one in my basement. I'll check this post later.
Re: 318 Truck Pan?? [Re: Dean_Kuzluzski] #992615
05/15/11 09:59 AM
05/15/11 09:59 AM
Thank you. I do appreciate your help.
Re: 318 Truck Pan?? [Re: S/ST 3040] #992616
05/15/11 11:29 AM
05/15/11 11:29 AM
moparx Online content
moparx  Online Content
just measured a 360 truck pan. it measures 4 1/4" in the front and a tick less than 9" in the rear [tallest part of the sump]. a 318 pan should be similar, as the only difference i am aware of is the main saddle diameter is bigger on the 360.
Re: 318 Truck Pan?? [Re: moparx] #992617
05/15/11 12:06 PM
05/15/11 12:06 PM
Thanks. Would you happen to have a picture from the side?
Re: 318 Truck Pan?? [Re: S/ST 3040] #992618
05/15/11 12:33 PM
05/15/11 12:33 PM
here's the only one i have. it's kinda crappy. hope you see what you need. if not, i'll take a couple more. i got a new camera, and i really don't like it much......
Re: 318 Truck Pan?? [Re: S/ST 3040] #992619
05/15/11 12:34 PM
05/15/11 12:34 PM
Andrewh Offline
Andrewh  Offline
I guess it depends on if you mean 5.2 magnum or actually a 318 LA block you are planning on putting into a newer truck.
when they 5.2 mag was put in, it was switched to 360 type seals.
so the 5.9 and the 5.2 use the same pan.
If you mean an actual 318 LA block, then the seals for the pan would be different.
Re: 318 Truck Pan?? [Re: Andrewh] #992620
05/15/11 12:39 PM
05/15/11 12:39 PM
It's for my car with a 340 and tubular crossmember.
Thanks for the picture. Now I need to track one down.
Re: 318 Truck Pan?? [Re: S/ST 3040] #992621
05/15/11 12:51 PM
05/15/11 12:51 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am going to order one of these today:
http://www.summitracing.com/parts/RNB-264-210/
I can measure it up if you want when it arrives. Not a bad price either.
Re: 318 Truck Pan?? [Re: moparx] #992622
05/15/11 12:57 PM
05/15/11 12:57 PM
Locomotion Offline
Locomotion  Offline
The rear seal area on a 360 is smaller than on a 318.
The front of the 360 and both ends of the 318 pan are the same.
A pan off of a V-8 Dakota has different overall measurements. Not sure of the seal configuration on Magnum engines.
Re: 318 Truck Pan?? [Re: S/ST 3040] #992623
05/15/11 03:22 PM
05/15/11 03:22 PM
Holly/MI
Holly/MI
I've got a pan off of an old mid-70's RV. It has a sump that is just less than 9" too. Like 8&7/8th's. Probably the same thing as in the pic above.
PM sent.
Re: 318 Truck Pan?? [Re: Locomotion] #992624
05/16/11 10:08 PM
05/16/11 10:08 PM
sorry on the mis-information. i knew one was larger, but i forgot which one it was. "oldtimers" ya know.........
