Re: 318 Truck Pan??
[Re: S/ST 3040]
#992614
05/15/11 09:50 AM
05/15/11 09:50 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
I can later, got to go out for a while. Got one in my basement. I'll check this post later.
Re: 318 Truck Pan??
[Re: moparx]
#992622
05/15/11 12:57 PM
05/15/11 12:57 PM
Posts: 5,895 Florida
Locomotion
just measured a 360 truck pan. it measures 4 1/4" in the front and a tick less than 9" in the rear [tallest part of the sump]. a 318 pan should be similar, as the only difference i am aware of is the main saddle diameter is bigger on the 360.
The rear seal area on a 360 is smaller than on a 318.
The front of the 360 and both ends of the 318 pan are the same.
A pan off of a V-8 Dakota has different overall measurements. Not sure of the seal configuration on Magnum engines.
Re: 318 Truck Pan??
[Re: S/ST 3040]
#992623
05/15/11 03:22 PM
05/15/11 03:22 PM
Dean_Kuzluzski
Holly/MI
I've got a pan off of an old mid-70's RV. It has a sump that is just less than 9" too. Like 8&7/8th's. Probably the same thing as in the pic above.
PM sent.
Re: 318 Truck Pan??
[Re: Locomotion]
#992624
05/16/11 10:08 PM
05/16/11 10:08 PM
Posts: 19,591 north of coder
moparx
sorry on the mis-information. i knew one was larger, but i forgot which one it was. "oldtimers" ya know.........
