Re: Throttle Return Spring for 440-6 Setup?
[Re: stan1970]
#99158
08/03/08 08:28 PM
08/03/08 08:28 PM
Depends if it is a 4 speed ot not. Smaller spring towards the rear of the carbs is for the kickdown.
[Re: stumpy]
#99160
08/03/08 08:42 PM
08/03/08 08:42 PM
First picture was of a survivor 6 pak car with a auto trans. This is of my 4 speed car. (yeah...I know the spring is the wrong color ![](/ubbthreads/images/graemlins/whistling.gif) )
#99161
08/03/08 08:45 PM
08/03/08 08:45 PM
Posts: 32,984 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Lots of guys put a smaller diameter but same length spring inside the other on the setup you have.
[Re: stumpy]
#99162
08/04/08 08:20 AM
08/04/08 08:20 AM
there is a throttle spring coming in from the front and a kickdown spring coming in from the back on automatics. the kickdown spring on makes sure the kickdown rod is in the forward position. it does nothing to the throttle lever.
a third skinny spring is sometimes added to the center of the front spring as a safety backup in case the first spring breaks
