What springs pressure is good for this cam?? #990984
05/12/11 03:20 PM
05/12/11 03:20 PM
Canada/USA
ragingram Offline OP
Canada/USA
I posted awhile back about this cam and now I have another question.
I called LSM about what Spring pressure i would need for this cam and they just told me to use there L700 B spring.
I wanted to know what pressures I would need because I have two sets of lightly used PSI springs and set new in box. I rather use one of these three sets then buy a whole new set.
I can play with the spring hieght a good amount to get more pressure if needed and still stay at .060 from bind.
What Open/closed pressures do you think is needed for this cam.
Ill try and post the cam card.
1.8 rockers
THANK YOU!
Re: What springs pressure is good for this cam?? [Re: ragingram] #990985
05/12/11 03:26 PM
05/12/11 03:26 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Whats that cam for?? Seems to have some odd specs to me.
Re: What springs pressure is good for this cam?? [Re: RemCharger] #990986
05/12/11 04:39 PM
05/12/11 04:39 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
around a 3.5 lobe lift at 1.5 1.8 is a 630 lift on the intake So 210 220 on seat pressure would work @ 1.950
Re: What springs pressure is good for this cam?? [Re: ragingram] #990987
05/12/11 04:46 PM
05/12/11 04:46 PM
Get-X Offline
Get-X  Offline
I'll assume the lift numbers are at the lobe and the duration is @.050. If so you'll need 400#+ seat and 1100#+ open depending on valve size, cubic inches, induction, number of carbs, intended use and rpm range and so on.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: What springs pressure is good for this cam?? [Re: ragingram] #990988
05/12/11 09:01 PM
05/12/11 09:01 PM
NC
440Jim Offline
440Jim  Offline
NC
IMO,
There is not enough information on that cam card to make spring pressure recommendations. I can't tell if the lift intensity from 0.050" to 0.100" and 0.200" etc is soft or hard.
Also the rpm, valve train weights, etc. play a role.
What are the springs pressures for the springs the cam manufacturer recommends?
Re: What springs pressure is good for this cam?? [Re: 440Jim] #990989
05/12/11 09:32 PM
05/12/11 09:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Holy cow that cam has 116 LCA, and those specs are given to install the cam straight at 116 ICL..
Must be a Blower cam IMO...
I also noticed its a 4-7 swap..
I would do some asking around to see if anyone has actually tried this cam in a similar application..
This thing would make zero power in your average Big Block Bracket engine...FACT
Re: What springs pressure is good for this cam?? [Re: Bob_Coomer] #990990
05/12/11 09:36 PM
05/12/11 09:36 PM
Canada/USA
Canada/USA
This engine is going in a Mini Modified tractor for tractor pulling.
it is a 620ci and spins 7500-8000rpm for 90% on its run.
it runs on alchy injection.
LSM told me to set it at 112. Intake center line.
Titanium 2.40 int valves. All T/D rockers
Also LSM had this entire engine for awhile so they seemed to know what they were doing with the cam
