guages no work #989894
05/10/11 08:13 PM
05/10/11 08:13 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
okay electric gurus none of my gauges work either I do have dash lights but everything else is dead. heater also
I hate wiring
Re: guages no work [Re: AB&E] #989895
05/10/11 10:15 PM
05/10/11 10:15 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Alot of gauge clusters have a 5 volt regulator in back of the dash panel. It is a thermal type so the contacts or heater can go bad. Looks like about 1/3 of a 9v battery with the same snap connections on it and a bracket to secure it in place. If the regulator isn't getting power, check the fuses & harness. If the gauges aren't getting voltage check the output from the regulator (it pulses 12 VDC on and off to achieve 5 VDC). If you don't have a service manual, try here: Mopar Wiring Diagrams
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: guages no work [Re: AB&E] #989896
05/10/11 10:39 PM
05/10/11 10:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
year and model would be nice. By none of your gauges I assume that includes the ammeter? If so it isn't your IVR (instrument voltage regulator) since the Ammeter doesn't use it. Bad grounding is my guess If the ammeter works then it's probably the IVR.
Don't be the exception.
