need help assembling 273 adjustable rockers #989854
05/10/11 06:55 PM
05/10/11 06:55 PM
Portland,Or
chargersNW Offline OP
Portland,Or
I got them in a box disassembled. If I can get a pic that shows how they look assembled. Especially the shim and spacer location. That would be great. Thanks
Re: need help assembling 273 adjustable rockers [Re: chargersNW] #989855
05/10/11 08:01 PM
05/10/11 08:01 PM
The center assy in the pic. The arrows point to the thick spacers. there are no (thin) shims OE but if that is what you are referring to they can b added to get exact lateral arm/valve tip orientation
Re: need help assembling 273 adjustable rockers [Re: chargersNW] #989856
05/10/11 08:10 PM
05/10/11 08:10 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You can very easily assemble as installing. locating the spacers and rockers as they best center on the valve stem.
Re: need help assembling 273 adjustable rockers [Re: chargersNW] #989857
05/10/11 09:20 PM
05/10/11 09:20 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The rocker shafts you use with those rockers should have bananna grooves cut in them to keep the rockers lubed. You will also need non-stock pushrods if you want to run the adjustable rockers with hydraulic lifters.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: need help assembling 273 adjustable rockers [Re: GO_Fish] #989858
05/10/11 09:27 PM
05/10/11 09:27 PM
Upper Midwest
Upper Midwest
Right - you can't run the 273 push rods with hydraulic lifters. The 273 solid lifter push rods are way too long and will bottom the lifter plunger out on a hydraulic lifter very possibly holding eh valve open.
I have used several times the push rods from summit for adjustable rockers and hydralic lifters. They worked fine.
Re: need help assembling 273 adjustable rockers [Re: MoparforLife] #989859
05/11/11 01:52 PM
05/11/11 01:52 PM
Portland,Or
Portland,Or
thanks for the advise. It seems when I assemble them as seen in the pic. I have spaces between the rockers and the hold down washers. What keeps the rocker from mooving side to side?
Re: need help assembling 273 adjustable rockers [Re: chargersNW] #989860
05/11/11 03:39 PM
05/11/11 03:39 PM
The (5) bolt/holddown assy's: use the shorter ones on the (2) end(s) and the middle and the 2 longer ones in between
