Looking at purchasing a carb spacer to help heat soak to the carb. I have used phenolic spacers in the past with good success. While shopping for a new one, I see that Edelbrock sells a wood fiber laminate piece. In the Summit description, Edelbrock claims it is ideal for reducing heat transfer. I have read here on Moparts that some members use wood carb spacers with good success. Is the wood fiber laminate combarable to a real wood piece and better than the phenolic or is it just a wannabe woody
Thanks in advance.
