Let's see your electric fuel pump install #989116
05/09/11 09:31 PM
05/09/11 09:31 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
looking for ideas about where to install an electric fuel pump. Interested in seeing 68-70 b bodies..Thanks
Re: Let's see your electric fuel pump install [Re: kbcuda] #989117
05/09/11 10:44 PM
05/09/11 10:44 PM
QLD Australia
Keith Black® Offline
QLD Australia
I've posted my Pic's in the racing forum:
https://board.moparts.org/ubbthreads/show...e=0#Post6309847
Darren Beale
Keith Black Racing Engines®
Re: Let's see your electric fuel pump install [Re: Keith Black®] #989118
05/09/11 10:45 PM
05/09/11 10:45 PM
QLD Australia
QLD Australia
2xA1000 Aeromotives speed controlled/staged.
2:
Darren Beale
Re: Let's see your electric fuel pump install [Re: Keith Black®] #989119
05/10/11 08:08 AM
05/10/11 08:08 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
That's a beautiful set-up with awesome fab-work. Just a little over the top for my needs and budget. I just need to mount a simple electric pump under the car with the original sending unit in place.
Re: Let's see your electric fuel pump install [Re: Keith Black®] #989120
05/10/11 09:18 AM
05/10/11 09:18 AM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
You can see it in this picture
Not the most out of site mounting , but with 3" exhaust it leaves little room to hide anything else.
Fed from a sump welded into a stock tank thru about a #12 stainless braided line. Filter is mounted inline prepump - just aft of the pump itself.
Pump is similar to this
http://www.product-engr.com/PE_4300.htm
[image]http://www.product-engr.com/PE_4300.htm[/image]
Enjoy life today, It has an expiration date
Re: Let's see your electric fuel pump install [Re: gtx6970] #989121
05/10/11 07:16 PM
05/10/11 07:16 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I have my Carter electric pump mounted in the axle tunnel. I did not want to drill any new holes so I hade a mounting plate picking up existing holes and installed the pump on that plate. I have it set up with a check valve in parrallel with the pump as I mainly use it to prime the two carbs (stock Hemi) as the fuel tends to evaporate after a week or so...
Re: Let's see your electric fuel pump install [Re: gtx6970] #989122
05/10/11 07:51 PM
05/10/11 07:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That line that I can see in the picture is a #10 at best, might be a #8? I don't care for the mounting position of that pump on that car. I mean it's great because it's below the tank where it should be, but it sticks out like a sore thumb. imo Kinda looks like it could be hit down there with something?
Re: Let's see your electric fuel pump install [Re: 68jim] #989123
05/10/11 07:53 PM
05/10/11 07:53 PM
Cincinnati, Ohio
Cincinnati, Ohio
Now that is a pretty slick setup there, except for the forged 90 degree fittings. It would be better with tube 90s. Yes I would have trouble drilling holes on your car also. Nice job I like it.
Re: Let's see your electric fuel pump install [Re: Challenger 1] #989124
05/11/11 05:28 PM
05/11/11 05:28 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
The pump fits pretty well in the axle tunnel, even with the Dana 60 taking up extra room. The fitting are #8 or 1/2" size. I just got really tired of having to prime the carbs with gas from a ketchup squirt bottle every time I wanted to start it up - Open the hood, pull the breather, fill the bottle, prime the carbs and start the car, install the breather, shut the hood... All while having to explain my actions to whomever the audience was at the time... Once the car is running the Carter mechanical pump provides plenty of gas. I also did not like having to run the starter for 30 seconds plus to try and start the car. So now I only use it to prime the carbs, it takes maybe 15-20 seconds and I can hear the gas fill into the bowls and the pump changes tone when all is full and pressurized. I turn the pump off, pump the gas pedal twice, and hit the key to fire it up. If gasoline ever gets "better" I can easily remove the pump and lines and put it back to factory correct in about an hour or so. The check valve in parallel allows the mechanical pump to pull past the electric pump direct from the tank. The electric pump pushes the check valve closed and pressurizes the fuel lines through the mechanical pump to up to the carbs. Pretty simple and works great. The Russel fittings got kind of pricey but made the set-up very compact vice using cheap fittings and lots of hose clamps. Probably not for everyone but it works for me. Good luck to the OP.
Re: Let's see your electric fuel pump install [Re: 68jim] #989125
05/11/11 09:09 PM
05/11/11 09:09 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mine is not visible from any angle. It's in the tank
Rock Valley make a cool baffle that I use on the EFI system that does not loose prime ( no bowls in an EFI system so it will stall)
Re: Let's see your electric fuel pump install [Re: kbcuda] #989126
05/12/11 12:49 AM
05/12/11 12:49 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Depends a lot on the pump. The vast majority of pumps have to be mounted below the fuel level. I thought that sucked, so I went with a Product Engineering pump. One of the few that can be mounted above the fuel level.
They are nice units.
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI.
1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
Re: Let's see your electric fuel pump install [Re: jbc426] #989127
05/12/11 01:19 AM
05/12/11 01:19 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Jim's set up is top notch.
I dont have pics but I put mine in the area between the outside frame rail and the wheelhouse on the passenger side. It is mounted to the frame rail, is out of the way, quiet and works great. Been there for almost 16 years...!
I am using a Mallory 140 with regulator, feeding into the stock mechanical pump.
