Re: T&D ROCKERS ON INDY 440-1 HEADS
[Re: steeldust]
#987264
05/06/11 07:17 PM
05/06/11 07:17 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
What diameter springs you running? 1.625 and larger hits, I have been told... I run Jesel stuff.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: moparniac]
#987266
05/06/11 08:12 PM
05/06/11 08:12 PM
Posts: 903 Saskatchewan, Canada
cudabin
We ended up running lash caps on my 440-1 heads w/Jesel 1.7 rockers, but not for rocker clearance, it was to correct the rocker tip to valve geometery. This was done even after we milled the steel jesel rocker stands a bit... We could have miled the heads a bit more, but then you lose even more thread engagement.
Lash caps were the best fix...
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: 440Jim]
#987268
05/06/11 10:33 PM
05/06/11 10:33 PM
Posts: 469 Tennessee
steeldust
Tennessee
Thanks for sharing.
What ratio rockers did you order? Is this the single shaft system or individual shafts for each rocker pair?
They are 1.6 T&D single shaft and the springs are 1.55 the rockers would touch but i put caps on them it's close but it will work and i order my push rods today i got a set of smith Bros . ![](/ubbthreads/images/graemlins/2231195-dggif.gif)
[Re: Bob_Coomer]
#987269
05/06/11 10:48 PM
05/06/11 10:48 PM
steeldust
Tennessee
I have 1.55 because that's what i have read but it was not the spring size but you could not run any thing bigger i think it was the retainer the way they are made but i could be wrong but the caps work. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: steeldust]
#987270
05/07/11 01:26 PM
05/07/11 01:26 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
1.55 on my 440-1 heads required lash caps.
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: Kevins493]
#987272
05/07/11 08:10 PM
05/07/11 08:10 PM
steeldust
Tennessee
We just talked to T&D and decided to mill the rockers. I don't like lash caps.
The black INDY rockers i broke 3 of the offset rockers last year and i don't won't to do that with this motor because i got a lot bigger cam so i am going to try lash caps. ![](/ubbthreads/images/graemlins/luck.gif)
[Re: steeldust]
#987273
05/08/11 01:20 AM
05/08/11 01:20 AM
Posts: 2,379 MD
Kevins493
MD
What spring pressure are you running? I run 805 over the nose on mine. They said it would be safe to mill them the amount that I did at that pressure. Not arguing with you, i just prefer not to run the caps because its just one more thing that can go wrong.
[Re: Kevins493]
#987274
05/08/11 09:00 PM
05/08/11 09:00 PM
steeldust
Tennessee
last year i had about 235 lbs pressure i had a 640 int 640 exh roller NOS cam and had a 150 shot on it i broke one just starting the car and i know three guy that broke them to and they went to jesel rockers and i know one guy he has run them for years and has not broke one . ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: robnbird]
#987276
05/08/11 10:49 PM
05/08/11 10:49 PM
steeldust
Tennessee
I use Harlan Sharp 1.5 1.625 springs. I did have a problem breaking the adjuster screws. However HS gave me great service new screws at no cost to me. I have had no problems sence and it probably was my fault. I tightened the adjusters to tight.
Hey you got a killer looking BIRD man is that a 1968 i had a 1969 i run for about 18 years i sold it in 2005 and quit racing but i could not stay out long so i have raced my DUSTER for three years you got a nice car good luck racing. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: steeldust]
#987277
05/08/11 11:47 PM
05/08/11 11:47 PM
Posts: 914 tn
robnbird
tn
Thank you very much, It fun to drive and so easy I think my 77yr old lady neighbor could drive it. She probably would to. I like dusters, I had a 70 340 duster in 1971-1973. This 68 is actually a sport satellite. Listen to this Herb McCandless' brother in law use to own it. Herb actually did the sheetmetal work in trunk and the tubs. He did a great job. It has a narrowed 60 diff 4 link. I recently changed the inspection cover and around the flat furface behind the cover it was stamped McCandless along with some numbers. Is that neat? They raced a 383 727 in footbrake. Where it Tenn are you. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: robnbird]
#987278
05/09/11 12:39 AM
05/09/11 12:39 AM
steeldust
Tennessee
I am in CROSSVILLE i am 16 miles from I-40 DRAG strip and 32 miles from Buffalo Valley Drag strip . ![](/ubbthreads/images/graemlins/beer.gif)
[Re: robnbird]
#987280
05/09/11 02:31 PM
05/09/11 02:31 PM
Posts: 901 oh
julian2007
oh
lsm make a great tool for that.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: 68roadrunner]
#987281
05/09/11 08:03 PM
05/09/11 08:03 PM
steeldust
Tennessee
will you be at the valley memorial weekend, i am on the fence about coming.
I have not run my DUSTER at the valley i have only run at BOUNTY heads up races but i got some friends run there i will see are you going to run i run my ROADRUNNER at the valley all the time it was a black 1969 and on the side of the car it was called WINGED WARRIOR it run 5.90s if you came to valley you most likey seen the car. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: steeldust]
#987282
05/10/11 01:27 AM
05/10/11 01:27 AM
Posts: 877 ky
68roadrunner
ky
only been there twice once last year and then three weeks ago. say hi if you see me
