Lifter bushing hole size? #986483
05/05/11 10:32 AM
05/05/11 10:32 AM
Vidor Texas
O
onyxba Offline OP
onyxba  Offline OP
O
Vidor Texas
What size hole is recommended in a lifter bushing to pushrod oil jesel rockers? I don't want to starve the top end but also don't want to push too much oil up top. Thanks in advance. Brian W.
Re: Lifter bushing hole size? [Re: onyxba] #986484
05/05/11 11:17 AM
05/05/11 11:17 AM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
We drill the bushings with a 3/16" drill and have 0.040" restrictors built into the push rods.
Larry
Re: Lifter bushing hole size? [Re: lowflyingdart] #986485
05/05/11 12:43 PM
05/05/11 12:43 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
We drill a .060 hole in the bushing and use a .020 restricter hole in the pushrod.
Re: Lifter bushing hole size? [Re: lowflyingdart] #986486
05/05/11 01:22 PM
05/05/11 01:22 PM
Out West
408strokerdart Offline
Out West
Larry
What he said....then control the oil with the pushrod restrictors. Don't know why any size between 1/16 and 1/8 would not work just fine either since I don't know of anyone running larger than .050 restrictors in their push rods. Might be wrong, but I would say most are between .025 and .040.
Re: Lifter bushing hole size? [Re: 408strokerdart] #986487
05/05/11 05:48 PM
05/05/11 05:48 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
.028"
Re: Lifter bushing hole size? [Re: onyxba] #986488
05/05/11 08:42 PM
05/05/11 08:42 PM
AndyF Offline
AndyF  Offline
Hole size shouldn't matter too much, just make sure that you put it in the correct location. If you do it correctly, the lifter clearance is used as the flow restriction and you don't need to pay extra to have restrictors inside the pushrods.
Re: Lifter bushing hole size? [Re: AndyF] #986489
05/06/11 12:09 PM
05/06/11 12:09 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I put two .025" holes in the bushing and it is way more than enough. My pushrods have a .050 hole in them.
Good Luck
Re: Lifter bushing hole size? [Re: AndyF] #986490
05/06/11 06:26 PM
05/06/11 06:26 PM
Sweden
ppmracing Offline
ppmracing  Offline
Sweden
Andy F is right,,,, go for 0,060-0,080" hole,,,
