Cuda started making a loud "whining" noise (video)
#985899
05/04/11 01:58 AM
05/04/11 01:58 AM
Posts: 227 Scottsdale, AZ
Cudalord
Scottsdale, AZ
Posting this in the hopes that someone may have experienced this and can give me some tips before I crawl under it this weekend.
Specs: 440, 727 with B&M Shift Kit & TCI BreakaWay torque converter, 3:23 8.75 Sure Grip Rear with MP "Green" Wheel Bearings.
It only happens when I decelerate (let off on the gas and let the car coast). When I give it some gas, the noise goes away, when I let off, it immediately comes back. If I'm going up to speed or on the gas, no issues, only happens when I decelerate. It started off a very low pitched whine, now as you can hear, it is pretty loud.
I attached a video with sound, hopefully you can access it. It appears that the noise is coming somewhere from the center/rear of the car, but I can't be certain as it is pretty loud and high pitched.
Any thoughts or suggestions? Thanks!
Re: Cuda started making a loud "whining" noise (video)
[Re: Cudalord]
#985902
05/04/11 08:53 AM
05/04/11 08:53 AM
Challenger 1
Cincinnati, Ohio
If it were me, I'd take a look before I went posting on the internet and then ask questions. Do you want us to fix it too?
[Re: Cudalord]
#985905
05/04/11 11:08 AM
05/04/11 11:08 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'm sorry, I thought this was a question and answer board. Thanks to you that actually gave some suggestions.
yeah I didn't get that reply either. As mentioned sounds like your rear is about done. I'd probably pull the chuck and see how it looks. How/when did this start? was it after a weekend of beating or a gradual thing? 3.23's + heavy car + hard launch = stress on ring/pinion
[Re: Mr.Yuck]
#985906
05/04/11 11:23 AM
05/04/11 11:23 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Also check the MP greenies , they aren't as good as the units Dr. Diff sells ... so I read on the internet ... but that definitely sounds like a rear end noise.
[Re: Cudalord]
#985907
05/04/11 11:36 AM
05/04/11 11:36 AM
Challenger 1
Cincinnati, Ohio
If it were me I would have slid under the car as soon as I heard it and grabbed/checked my U joints and at the same time checked to see if my pinion nut was loose. Then posted my findings asking for advise.
[Re: Challenger 1]
#985908
05/04/11 11:55 AM
05/04/11 11:55 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
You do realize that without knowing to begin looking at the u-joints and/or pinion, he'd have a pretty hard time beginning the diagnosis.
To the O/P, I had a very similar noise at one time. Turned out to be my pinion nut losing up on me as other previous posters have mentioned. And don't worry about Challenger. You did a way better job initiating a Q&A topic than most people who would have just said, "Have this annoying noise occurring. What is it?"
[Re: Pat_Whalen]
#985909
05/04/11 12:09 PM
05/04/11 12:09 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
FWIW the video is nice but you get no sense of direction/location of where the noise is coming from.. I agree it is probably a loose pinion nut but many years ago I heard a failed convertor make a similar sound & knowing the location would help in diagnosis...
[Re: RapidRobert]
#985911
05/04/11 09:20 PM
05/04/11 09:20 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
sounds more like excessive play in the gears, than it does a bad bearing. check the fluid level yet? if/when you pull it apart, be sure to check the oil, maybe drag a magnet through it, see if you lost any metal, and if so, how much. fwiw, that vid was a good idea, made it easier to hear the whine, instead of just hearing a description.
[Re: Cudalord]
#985913
05/05/11 09:59 AM
05/05/11 09:59 AM
JohnRR
Thanks guys for the tips, it really give me some direction. To answer a few questions:
1. The Video was strictly to give you an idea of the noise pattern, the coming and going of the noise is me decelerating/accelerating, I had no intention of you being able to figure out where it was coming from.
2. The pig was used when I got it, mileage unknown. The first thing I did was check the fluid level and that was last weekend, it was right where it should be and the fluid was clear.
3. This occurred over a period of about 2 weeks, of daily driving, it started out as a very low pitched/intermittent noise.
What case number is it ?
[Re: Cudalord]
#985916
05/07/11 09:16 AM
05/07/11 09:16 AM
Posts: 10,777 North Dakota
6PakBee
North Dakota
It would be interesting to know just what failed in the rear end. I have never heard a differential sound like that. Wow.
