Re: what will it run?? [Re: plasticfantastic] #985881
05/04/11 04:15 PM
05/04/11 04:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
First I'll throw out a guess just for fun, and I'll just say 10.84 for no particular reason It just seems to make sense right now....
Second I'd like to know what the secret is to getting a car weighed at Milan? After about 10 times of "the scales are broken" and "there's nobody there to do it" I gave up asking...
Rich H.
Esse Quam Videri
Re: what will it run?? [Re: ZIPPY] #985882
05/04/11 04:35 PM
05/04/11 04:35 PM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Zippy,it was a national event.Jim the car went 11.40@98 getting out of it at half track with the old set up ,of eddy head and a 590 mopar cam and the 6 pack on it.
Re: what will it run?? [Re: pro6pakRR] #985883
05/04/11 04:36 PM
05/04/11 04:36 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Figures
Rich H.
Esse Quam Videri
Re: what will it run?? [Re: Labratt] #985884
05/04/11 09:12 PM
05/04/11 09:12 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I dont know about the 70 but my 71 weighs 3845 without me in it
Re: what will it run?? [Re: BLONDE BARRACUDA] #985885
05/04/11 10:27 PM
05/04/11 10:27 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Doug, I think your dad would be happy sitting in a red wagon with you pushing him Good luck with the new combo and I look forward to seeing you guys out this year
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: what will it run?? [Re: BLONDE BARRACUDA] #985886
05/04/11 10:31 PM
05/04/11 10:31 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
do you have pics of the 71 ?
1.39 9.85 - 137 mph
Re: what will it run?? [Re: G-Money1320] #985887
05/04/11 11:00 PM
05/04/11 11:00 PM
toledo, ohio
plasticfantastic Offline OP
toledo, ohio
that would be a site to see, my dad in a red wagon with me trying to push him....
We're gonna try and make it out as much as possible, We'll see you at MCIR in July?
Re: what will it run?? [Re: 1967dartgt] #985888
05/04/11 11:30 PM
05/04/11 11:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With your overall gearing the best that you can run is about a 10.60 to 10.80 @ 7300 to 7500+ RPM
WHAT? How much convertor slip does he have 50%? Have gone way faster then that with the same gear and smaller tires and turned that rpm.
Of Course, its a heavy car
No I used a conservitive 5% and 8% calc for vert slip. With a base MPH of 126, for a best ET of around 10.6 since its a heavy car.
MPH x gear x 336/ tire diameter + X vert slip.
I think the OPs car has 10.5 potential But that 4.86 gear and 29.5 tire will limit its ET potential by RPM
Id say 10.9,s are in the bag with the New combo for starters.
Re: what will it run?? [Re: BLONDE BARRACUDA] #985889
05/05/11 08:46 AM
05/05/11 08:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my old 67 coronet weighed 3850 w/ me and 1/2 tank of gas. (I'm about 185) I'm sure his GTX w/ dana and a heavier driver could be close to 3900.
Re: what will it run?? [Re: Mr.Yuck] #985890
05/05/11 09:51 AM
05/05/11 09:51 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Sooooo, any work done to the heads? BS heads flow OOTB is pretty bad, esp at lower lifts?
As bad as BS heads are OOTB, if they havent had some work, Id say high 10s.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: what will it run?? [Re: Mr.Yuck] #985891
05/05/11 09:58 AM
05/05/11 09:58 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
At Race weight my old 67 Coronet R/T with dana 60 & Big block topped the scales at a tad over 2800 lbs.And another 230 lbs or so for me. There was not much more than a hull with a cage left,in other words I ruined a extra nice 67 R/T. I won 2 Track Championships with it & it also was a Killer Grudge Race car. I won enough $$$ with it to have my 1st dragster built.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: what will it run?? [Re: Ari440] #985892
05/06/11 12:02 AM
05/06/11 12:02 AM
Wisconsin
Wisconsin
I am not sure how to put pictures on here I wanted to put a picture of my barracuda on but cant the only thing I could put on is the small picture by my sig.
Re: what will it run?? [Re: Von] #985893
05/06/11 02:05 AM
05/06/11 02:05 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Yes there has been alot of work done on the head's.The car they were in before went 9.50.in a Maverick.
