Re: what will it run??
[Re: plasticfantastic]
#985881
05/04/11 04:15 PM
05/04/11 04:15 PM
Posts: 17,919 S.E. Michigan
ZIPPY
S.E. Michigan
First I'll throw out a guess just for fun, and I'll just say 10.84 for no particular reason ![](/ubbthreads/images/graemlins/smile.gif) It just seems to make sense right now.... Second I'd like to know what the secret is to getting a car weighed at Milan? After about 10 times of "the scales are broken" and "there's nobody there to do it" I gave up asking...
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#985882
05/04/11 04:35 PM
05/04/11 04:35 PM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
Zippy,it was a national event.Jim the car went 11.40@98 getting out of it at half track with the old set up ,of eddy head and a 590 mopar cam and the 6 pack on it.
[Re: G-Money1320]
#985887
05/04/11 11:00 PM
05/04/11 11:00 PM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
Doug, I think your dad would be happy sitting in a red wagon with you pushing him Good luck with the new combo and I look forward to seeing you guys out this year
that would be a site to see, my dad in a red wagon with me trying to push him....
We're gonna try and make it out as much as possible, We'll see you at MCIR in July?
[Re: 1967dartgt]
#985888
05/04/11 11:30 PM
05/04/11 11:30 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
With your overall gearing the best that you can run is about a 10.60 to 10.80 @ 7300 to 7500+ RPM
WHAT? How much convertor slip does he have 50%? Have gone way faster then that with the same gear and smaller tires and turned that rpm.
Of Course, its a heavy car ![](/ubbthreads/images/graemlins/laugh2.gif)
No I used a conservitive 5% and 8% calc for vert slip. With a base MPH of 126, for a best ET of around 10.6 since its a heavy car.
MPH x gear x 336/ tire diameter + X vert slip.
I think the OPs car has 10.5 potential But that 4.86 gear and 29.5 tire will limit its ET potential by RPM
Id say 10.9,s are in the bag with the New combo for starters. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: BLONDE BARRACUDA]
#985889
05/05/11 08:46 AM
05/05/11 08:46 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I dont know about the 70 but my 71 weighs 3845 without me in it
my old 67 coronet weighed 3850 w/ me and 1/2 tank of gas. (I'm about 185) I'm sure his GTX w/ dana and a heavier driver could be close to 3900.
[Re: Mr.Yuck]
#985890
05/05/11 09:51 AM
05/05/11 09:51 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Sooooo, any work done to the heads? BS heads flow OOTB is pretty bad, esp at lower lifts?
As bad as BS heads are OOTB, if they havent had some work, Id say high 10s.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Mr.Yuck]
#985891
05/05/11 09:58 AM
05/05/11 09:58 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
At Race weight my old 67 Coronet R/T with dana 60 & Big block topped the scales at a tad over 2800 lbs.And another 230 lbs or so for me. ![](/ubbthreads/images/graemlins/grin.gif) There was not much more than a hull with a cage left,in other words I ruined a extra nice 67 R/T. ![](/ubbthreads/images/graemlins/frown.gif) I won 2 Track Championships with it & it also was a Killer Grudge Race car. ![](/ubbthreads/images/graemlins/thumbs.gif) I won enough $$$ with it to have my 1st dragster built.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Von]
#985893
05/06/11 02:05 AM
05/06/11 02:05 AM
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
Yes there has been alot of work done on the head's.The car they were in before went 9.50.in a Maverick.
