Re: Is Cuda and Challenger side glass the same?
[Re: Choppintime]
#985176
05/03/11 12:02 AM
05/03/11 12:02 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Thanks. But am I correct to say the inner regulators, etc are different on the Cuda and Challenger?
IIRC only the rear qtr regulators of each of the convertibles are seperate enities,...the hardtops regs are the same, front or rear, with the exception of electric lifts,...contact Randy (1 wildRT IIRC) he's up on the E body window regs/glass, what works and what can be made to work
Mike
[Re: Choppintime]
#985177
05/03/11 12:03 AM
05/03/11 12:03 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The regulators are different due to the length of the shaft for the crank handle... Other than that they are the same...
Edit After seeing Mike's post Now I'm an E body tech guy... Thanks Mike!
The deal is E body power regulators are the same because they have no crank, Vert to hard top are different but it's a simple mod to convert a hardtop regulator to vert...
[Re: 1_WILD_RT]
#985178
05/03/11 12:55 PM
05/03/11 12:55 PM
Posts: 4,165 Florida
cataclysm80
Congratulations on the promotion Randy!
with what Randy said. I'd also like to add that the parts which are the same, mount using different holes on the door for barracuda vs. challenger. (all the holes are on all the doors, so carefull not to install in the wrong spot, or you'll have trouble when putting the door panel back on.)
Tav
