Re: cracked keisler BH
[Re: Sick 660r]
#985127
05/02/11 10:39 PM
05/02/11 10:39 PM
Posts: 791 Bama
Randy..
Bama
[Re: Randy..]
#985128
05/02/11 10:56 PM
05/02/11 10:56 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
no but i could trade you a tko and the bh for a dakota straight up. its a keisler kit as well.
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: Sick 660r]
#985130
05/02/11 11:12 PM
05/02/11 11:12 PM
wldtm
Dayton, Ohio
I know you wont want to hear this. But call and see if Richard is still at Keisler. I bet they would take care of it, and I would think shipping would be consumed as well.
You got any pictures of how the whole BH is designed?
PM for details
[Re: Sick 660r]
#985132
05/02/11 11:36 PM
05/02/11 11:36 PM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
Last time I sent shafi an email it was about my slave cylinder that took a dump with less than 2k miles and he ignored it.
How do you know he got it? An email is not the same as calling them in person.
[Re: Aero426]
#985133
05/02/11 11:44 PM
05/02/11 11:44 PM
Posts: 142 Maryland
Sick 660r
Maryland
because we used the same eamil address not too long before. Shafi and I are not on good terms to say the least. When you have forgotten more issues then you remember, you dont want to do business with the company anymore. If they cant build it right the first time there is no way im sending it back to them to fix it.
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: wldtm]
#985134
05/04/11 01:56 PM
05/04/11 01:56 PM
Posts: 227 Tennessee
rj8806
Tennessee
I appreciate the kind words, but I am no longer at Keisler. I am now working for American Powertrain (www.americanpowertrain.com ).
I am still on here though trying to help out when I can. In this case, the good news is it looks like it's not the bell housing and just the weld where they attached the adapter plate to the stock Mopar bell housing. I would imagine any competent machine shop could finish breaking the weld, remove the plate and then re-weld it back in place...?
Richard
[Re: Sick 660r]
#985140
05/04/11 10:02 PM
05/04/11 10:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats just bad prep and welding... that should have all been V ground and a ton of pre heating... thats 2 BIG heat sinks..... any decent welding shop can fix that for you
[Re: B G Racing]
#985142
05/04/11 11:01 PM
05/04/11 11:01 PM
MR_P_BODY
Cast to billit is difficult to weld,porus to dense materials,too much heat can be just as bad as not enough.Too much heat will cause expansion and shrinkage causing the weld or weaker material to crack and not enough heat will cause less penatration into the more dense of the two materials.
I've welded a few BH Bob... I use indirect pre heat
[Re: rj8806]
#985145
05/05/11 05:26 PM
05/05/11 05:26 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
I decided to go the Quicktime route for my T56. Top quality part.
-------------------------------- Darren Beale Keith Black Racing Engines®
