Re: 17 ' wheels on a 1971 Challenger convertible [Re: 71_dramaqueen] #983462
06/20/11 04:42 PM
06/20/11 04:42 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
The center register on Mustang wheels is about .039" smaller in diameter.
You can either open up the rims, or cut down the hub on your brakes/axles. If you run spacers on the rear that are wider than 1/4" you don't need to do it for the back.
Disc brakes in the front still have the issue even with 1 1/4" spacers.
I cut down my rotors in the front on a lathe to fit my rims.
1971 Challenger
Re: 17 ' wheels on a 1971 Challenger convertible [Re: cudazappa] #983463
06/20/11 06:47 PM
06/20/11 06:47 PM
BDW Online content
BDW  Online Content
The register on these specific rims is only a small rib, and not the whole opening. I was able to take off this 1/4" lip fairly easy.
