seat track bolt #983164
04/30/11 12:26 PM
04/30/11 12:26 PM
mn.
P
prairiechicken1 Offline OP
P
mn.
I have bad bolt on bench seat mount, does anyone sell matching bolts? Or do I have to find a seat track? thanks to all for the help
Re: seat track bolt [Re: prairiechicken1] #983165
05/01/11 12:36 AM
05/01/11 12:36 AM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
Look here:
Bolt
about half way down the page : 0998196 BOLT BATTERY TREMINAL/ SEAT TRACK
Re: seat track bolt [Re: prairiechicken1] #983166
05/01/11 11:02 AM
05/01/11 11:02 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm guessing, but this one ? if so how long do you need it to be ?
AFAIK, this is the only one avail ,,,,and I 'think' it's to short if you use in the phenolic spacers under the seat adjuster track assy.
Specs are - 5/16-18 x 1+7/16" length with a 1/2" Square Head
Re: seat track bolt [Re: gtx6970] #983167
05/01/11 03:14 PM
05/01/11 03:14 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I always seem to run into seat tracks that are missing one bolt. I just use a regular nut and bolt in its place.
However, You won't be able to just tighten the nut from underneath the car unless you back it up with a wrench at the seat track.
Re: seat track bolt [Re: Finoke] #983168
05/01/11 04:47 PM
05/01/11 04:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a '70 b-body bucket seat bolt w/a round head. 1-7/8" lg.
Re: seat track bolt [Re: 6bblgt] #983169
05/01/11 04:55 PM
05/01/11 04:55 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
square hole looks to be 11/32" (~0.35")
Re: seat track bolt [Re: 6bblgt] #983170
05/01/11 07:26 PM
05/01/11 07:26 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
...You could use a correct size/length carriage bolt...If you're real picky you could grind the convex head flatter to match the other 3...
