70 B Body Trunk Light ??? #983083
04/30/11 10:33 AM
04/30/11 10:33 AM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
1970 B Body Plymouth...
Where does the trunk light mount?
What type of switch does it use?
Same as a single prong door jamb light switch?
Pictures please
CHECK OUT MY NEW WEB SITE !
Re: 70 B Body Trunk Light ??? [Re: anlauto] #983084
04/30/11 11:31 AM
04/30/11 11:31 AM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
You're kicking back a percentage of your profit on this job to the forum for doing your background work for you, right?
The switch goes in that tab that's welded along the driver's side rail. It's a plunger like the door switches are, but I'mm not sure if they're the same or not.
The light goes under the package tray.
Everybody makes fun of a hillbilly until they need something fixed
Re: 70 B Body Trunk Light ??? [Re: B_Body_Bob] #983085
04/30/11 11:45 AM
04/30/11 11:45 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'll have to look and double ck, but I think it's the same switch as the park brake adjuster switch with a bullit style connector
Such as ,,,,,
Re: 70 B Body Trunk Light ??? [Re: B_Body_Bob] #983086
04/30/11 12:35 PM
04/30/11 12:35 PM
anlauto Offline OP
anlauto  Offline OP
Of course. it's quick fast and simple research...
Where abouts
Re: 70 B Body Trunk Light ??? [Re: B_Body_Bob] #983087
04/30/11 12:44 PM
04/30/11 12:44 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
look at his sig..
he is too cheap to buy a sponsorship
Re: 70 B Body Trunk Light ??? [Re: flypaper] #983088
04/30/11 05:43 PM
04/30/11 05:43 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Look under the dutch panel if it had a kite before and it will be the only screw hole. I t is about 15-18 inches over from the drivers side and toward the back. Good Luck Ronnie
Re: 70 B Body Trunk Light ??? [Re: okie] #983089
04/30/11 11:18 PM
04/30/11 11:18 PM
anlauto Offline OP
anlauto  Offline OP
Found it thank you...
