thrust washer difference Hemi vs 440?
#982725
04/29/11 08:33 PM
04/29/11 08:33 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
just wondering as I am getting a new crank made (...still..).. does the 440 crank use thicker thrust washers..? if so is there any difference between the thrust journal width of the hemi/440 crank or is the block different? May as well get better thrust washers as I will be running a reasonable dual-plate clutch (RAM) & I hear the thrusts can take a beating.
-------------------------------- Darren Beale Keith Black Racing Engines®
