new tires for 65 coronet with 15 inch rims. What to get #981842
04/28/11 11:23 AM
04/28/11 11:23 AM
Andrewh Offline OP
Andrewh  Offline OP
trying to decide on brand and size.
I don't want issues turning and rubbing.
I have a set of 15 inch rims I will be using.
right now I have 215 70 14's on it.
The pickings are slim for 235 60 15's. and am not sure if that is too wide or not.
I want the same size all the way around.
looks like my only brand choices are cooper, firehawk or bfg's if I want raised white letters.
Blackwall, I can go for anything realy if I give up the 235's and go for 215's or 225's.
Not sure how that will look.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981843
04/28/11 11:30 AM
04/28/11 11:30 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Cooper Cobra's are an excellent tire, and used them alot back in the 15" wheel days.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981844
04/28/11 11:35 AM
04/28/11 11:35 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Personally I'd run nothing smaller than 245/60/15 all around if you want them all the same size. I run 235/60/15 front and 275/60/15 rear.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Junky] #981845
04/28/11 12:03 PM
04/28/11 12:03 PM
Andrewh Offline OP
Andrewh  Offline OP
how stock is your car to get that under there?
any issues with turning or bumps?
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981846
04/28/11 12:40 PM
04/28/11 12:40 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Unless you have a crazy backspace you can run 255/60/15 with no problems on 15x7 wheels, easy.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Junky] #981847
04/28/11 12:56 PM
04/28/11 12:56 PM
Andrewh Offline OP
Andrewh  Offline OP
pretty standard, but I was more concerned about the front end.
I think 255's might be pushing on the back end. but the last time I tried that was with a 67 and it would not clear the lip.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981848
04/28/11 01:07 PM
04/28/11 01:07 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
65 and 67 are two totally different animals. Get that out of your head. The 255's will fill the wheel wells much better on a 65, and clear the rear just fine with 15x7 wheels. I know, I've ran them in different combos on my 65 Coronet. You can even run a 275 on a 15x7 wheel in the back OK, but it's tight. The 255 would look nice all the way around. I wouldn't go any smaller than 245 all around otherwise the tire will look too small if it's a 235 all around.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Junky] #981849
04/28/11 01:21 PM
04/28/11 01:21 PM
Andrewh Offline OP
Andrewh  Offline OP
thanks. That was my concern.
pretty much all the places I called don't have 15 inch tires in stock.
235's on paper look smaller as well but I was afraid I couldn't get anything bigger to fit.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981850
04/28/11 02:56 PM
04/28/11 02:56 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Use this to give you a good idea comparing tire sizes
http://www.miata.net/garage/tirecalc.html
FWIW, the 235 60 15 is almost identical in diameter to the 215 70 14
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: DPelletier] #981851
04/28/11 03:24 PM
04/28/11 03:24 PM
Andrewh Offline OP
Andrewh  Offline OP
thanks. that helps some too.
going to 245 or 255 pretty much limits me to the same sets as the 235's.
so cobra's, firehawks, or BFG's.
guess cobras have the lead in votes. anyone else?
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981852
04/28/11 06:08 PM
04/28/11 06:08 PM
DPelletier Offline
DPelletier  Offline
The cobras may be good tires, but the BFG's look better IMO. I might go with Eagle GTII's instead but sizing is limited.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: DPelletier] #981853
04/28/11 06:17 PM
04/28/11 06:17 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Around here, some of the BFG's are on super-duper-forever back order as well.... can't remember if it was the 225's ? 235's ? 245's ? (60 series that is)
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: OzHemi] #981854
04/28/11 06:38 PM
04/28/11 06:38 PM
Andrewh Offline OP
Andrewh  Offline OP
I noticed that too, but found that some places stock a new part number and have the 255 in stock.
While they may look better, I prefer the smaller white letters over the huge cooper one's, performance and longevity based on the stuff I see says cooper has the edge.
I wish goodyear made one in that size. I would be all over it. But they don't.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981855
04/28/11 06:45 PM
04/28/11 06:45 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Get some black paint and go around the Cooper writing until it's smaller.
Re: new tires for 65 coronet with 15 inch rims. What to get [Re: Andrewh] #981856
04/28/11 08:48 PM
04/28/11 08:48 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
245-60-15 on 7" police wheels all around on a 64 Polara,no problems.
