Re: NO MORE SPARK?
[Re: Joshs68]
#981586
04/27/11 10:20 PM
04/27/11 10:20 PM
RapidRobert
take off the coil neg pri wire(s) & key on, w a jumper ground the coil neg pri terminal to ground repeatedly like Morse Code & if that makes the coil secondary wire (dist end) held 1/4" from ground make sparks & if good the coil/ballast and their supporting wiring are good (though a coil can test good cold then act up w hot). then (key on) touch the male end of the dist 2 wire connector to ground (which I think you described) & see if that makes a sec coil wire spark & if not but it did on the 1st test that highly points to the ECU but do a quick check on the ECU related wiring (pull/reinstall the pentastar connector). If it sparks on both tests than that leaves the dist. visual check the pickup/gap & ohm it if you have a VOM. If the ECU is bad I'd have no prob w a $15 parts house Mopar type generic 4 pin replacement ECU
