Re: HONING WITH TRQ PlATES OVER RATED? [Re: sshemi] #981473
04/27/11 05:39 PM
04/27/11 05:39 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I got my world block from Ray Barton and he told me they hone with torque plate and heat ran thru the block.
Mopar Performance
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Guitar Jones] #981474
04/27/11 07:03 PM
04/27/11 07:03 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
I mean 7 tenths. 3.9 V6 in a Dakota. Same exact specs, cam, heads, intake everything except the shortblocks. The first one was not honed with a plate. The second one was and it picked up 7 tenths and became incredibly consistent where before it wasn't. YMMV
There had to be other things. I can't believe that a simple torque plate hone would result in ~3/4 of a second gain.
Something else had to be off in the first shortblock.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: HONING WITH TRQ PlATES OVER RATED? [Re: moparniac] #981475
04/27/11 07:05 PM
04/27/11 07:05 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Done it both ways. I have even used alluminum spacers on top of the plate and the original head studs to simulate the heads best I could. I don't know any practical way to do it because you need to stroke through the end of the cylinder but buttoms up with the head bolted on would be great IMO. But, no physical way to do it that I know of.
My opinion a block run at a certain bore for a season. Then bore over .005" new pistons and then do all the tricks you can when finish honing. Even bolt the heads to the block when final sizing the guides and lap the valves. OOOOPS did I give something away.
I let an engine get away that the block was done by Diamond for the Pro stock truck exhibition. They seasoned the block with a vibration process they do after every machining process. But, this was done on Mopars nickel. They never used these three blocks. But, it was a great one for me.
Leon
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981476
04/27/11 08:04 PM
04/27/11 08:04 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I'd always use a plate, and same fasteners, same thread engagement, same lube, etc.. Torque plate valve jobs have been around too since the 70's that I know of.
I know most of you might only get excited about air flow numbers, but all the air flow in the world won't make power, if it doesn't stay in the cylinder to work for you.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: LSP] #981477
04/27/11 08:34 PM
04/27/11 08:34 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
take a good look at the cylinder walls in as few a worn blocks. You will see that some of the previous honing cross hatch is still there.
It is always directly adjacent to the head bolts.That's 100% positive proof that they pulled the cylinder out of round. A plate would create the same consditoin but it gets corrected when honed
home of the
Sox and Martin Hemi Duster
Re: HONING WITH TRQ PlATES OVER RATED? [Re: daniel_depetro] #981478
04/27/11 09:04 PM
04/27/11 09:04 PM
Guitar Jones Offline
It's possible but with a stocker every little thing helps, and this is a small engine. The truck could hardly run the index before, now it's consistently under and deadly consistent as well.
Made me a believer.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Guitar Jones] #981479
04/27/11 10:36 PM
04/27/11 10:36 PM
ky
68roadrunner Offline
ky
one of my engines, machine work was done by an unknown to me machine shop, so i checked everything. cylinder bores a couple inches down measured very different, and all cylinders was the same. so i am sure they used the torque plates they were supposed to do.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: hemiiroc] #981480
04/27/11 10:59 PM
04/27/11 10:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Oh that could be but definitely had high and low spots!
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981481
04/28/11 12:23 AM
04/28/11 12:23 AM
utah
jjl Offline
jjl  Offline
utah
A filled block really has alot of distortion at the top,I always added it in on a performance build and recommended it on a stock build.
formally orangemonster
Re: HONING WITH TRQ PlATES OVER RATED? [Re: jjl] #981482
04/28/11 01:31 AM
04/28/11 01:31 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I think it is important to use the same type of head gasket also. I will say that I have to question the effectiveness of an aluminium torqueplate. I do wonder how well it simulates a cylinder head. I do know of some Comp guys that used thick cast iron plates to simulate their heavy W8 heads.
AL...
Alan Jones
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981483
04/28/11 04:03 AM
04/28/11 04:03 AM
New Zealand
Big-Mike Offline
Big-Mike  Offline
New Zealand
Well! I do have the difference in #'s.
I built my 1st 440 BB in 1987. Used a one inch steel plate that I had made. I had it machined so it was flat & even the indents where there is a protrusion on the underside of the Head-bolts.
I had a used Fel-Pro Gasket fitted as well.
After the finish hone, we released the plate to do a check to see what difference there was.
"Surprise", not at all! One inch down the bore it was "3-1/2 thou" at each bolt.
And that is right where all your cylinder pressure has peaked.
Hope this helps with making the only choice you should do.
Its Not over-rated.
Mike in New Zealand.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Big-Mike] #981484
04/28/11 04:28 AM
04/28/11 04:28 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I have checked on some blocks, and tore up blocks that did not have torqueplates during honing: I have measured appx .001" of distortion with / without plates during machining, but seen bigger variations with or without maincaps installed (though in the bottom of cylinders, not that important). In a 502 bbc block which is a high quality block I could not find any distortion after use, and with a 414 LA 12.5:1 stroker done without honing plates the rings had made a clean polishing all the way around after only a few miles of street driving (blew a headgasket, so took it apart). If working with an SBC it should be used, when measuring it looks like the pentastar. However, I think the most important is not the plate but to get the threads stressed. So if I do not have a torque plate I use bolts and spacers to stress the threads, seems to work well (enough for a street job). My
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981485
04/28/11 12:04 PM
04/28/11 12:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Long story short, it turned out that my 452 had NOT been honed w/ plates the previous time it was freshened up (despite the receipt stating it had). When the current machinist strapped down the plates, the top of the bore distorted significantly. The bad news is since the block was already .060" o.s. and the bores were on the loose side, we made the decision to simply re-hone it w/o the plates AGAIN because there wasn't enough material left to do it w/ them unless I was ready to drop the $$$ for custom 4.38+" pistons. So, I've run in the 10s w/ non-plate-honed bores and can't even guess how much that may have cost in peak performance... 5 HP? 10 HP?
Then we ran into the same situation where my backup 4.360" block that had also supposedly been done w/ plates also had NOT. This time I went ahead and had it re-done properly at a 4.375" bore. You can guess what my opinion is of the two other shops that were responsible for the earlier prep work.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: LA360] #981486
04/28/11 02:23 PM
04/28/11 02:23 PM
Delray beach, Florida
P
Performance Only Offline
P
AL...
Al, you may question the effectiveness, but i can tell you we've done extensive testing on the aluminum torque plates we manufacturer and they replicate the cylinder head extremely well. a lot more science goes in to making a proper torque plate than just hogging out some aluminum to fit a block. i'm sure many would be surprised what we went through with material types, thickness, counterbore depths etc. to get it right.
there are very few blocks where a torque plate won't make a difference, and none for a mopar they i've run into.
all of the factory blocks distort, even the mega blocks and R blocks.
machine shop owner and engine builder
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Performance Only] #981487
04/28/11 04:09 PM
04/28/11 04:09 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Brad, I've been there too. I would get charged for "hone with plate" and they wern't doing it. What tipped me off was that I would tell them not to clean the block, I would wash it myself so why pay them to do it. Anyway when I would go to pick it up there would be honing grit in both banks of the headbolt holes. It would seem to me one side atleast should look like a bolt just came out of it.
Well,that was the end of that. Pisses me off as I own both small and big block plates and I would leave them there. When I would pick the stuff up I could tell they hadn't been out of there crates but they would tell me they had used their own. Took me a few blocks to figure out what was going on.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: scatpacktom] #981488
04/29/11 08:29 PM
04/29/11 08:29 PM
QLD Australia
Keith Black® Offline
QLD Australia
..how many people gap their rings with torque plates on ..?
Darren Beale
Keith Black Racing Engines®
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Keith Black®] #981489
04/29/11 09:44 PM
04/29/11 09:44 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I can measure the change in bore size between the bolts without the head. Especially on a small block with 4 big bolts. It's critical on a modern rebuild IMO.
