4 speed and O/D shift rods #981024
04/26/11 05:43 PM
04/26/11 05:43 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
will the shifter rods on an 833 work on an 833 O/D? They are both A-body gear boxes
Re: 4 speed and O/D shift rods [Re: dustergirl340] #981025
04/26/11 05:54 PM
04/26/11 05:54 PM
Retired now in Tennessee
Chi_Town_Runner Offline
They should. I just did mine on a "B" body.
The only thing is that the 3/4 shift lever on the trans faces down, not up. This places the hole that the shift rod goes into a little further away from the shifter housng. I had enough adjustment on the shift rod to make up the difference.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: 4 speed and O/D shift rods [Re: dustergirl340] #981026
04/26/11 06:57 PM
04/26/11 06:57 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
great...thanks!
Re: 4 speed and O/D shift rods [Re: dustergirl340] #981027
04/27/11 11:44 AM
04/27/11 11:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 1-2 rod and reverse is the same , the 3/4 rod is different , I tried to use the non od rod on an OD trans I was thinking of using and the adjustment was all the way out at the end .
Re: 4 speed and O/D shift rods [Re: JohnRR] #981028
04/27/11 04:58 PM
04/27/11 04:58 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
thanks John!
