4 Speed and bell housing question #980862
04/26/11 06:48 AM
04/26/11 06:48 AM
Sydney NSW
Rodsports Offline OP
Sydney NSW
I have a 833 manual gearbox and the retainer (the raised area) is 125mm across. The small block bell housing (pn 3545 734) is 115mm across. Is this a big block gear box? or am I missing something. I bought this set up believing it came off a small block.
Re: 4 Speed and bell housing question [Re: Rodsports] #980863
04/26/11 10:05 AM
04/26/11 10:05 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
What is the casting number of the bearing retainer on the front of the transmission?
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 4 Speed and bell housing question [Re: 64dodge572] #980864
04/26/11 10:13 AM
04/26/11 10:13 AM
Boston, MA
crocha617 Offline
crocha617  Offline
Boston, MA
Sounds like you have a large bearing 4 speed (usually used on big blocks)and a small block bell housing (for the smaller bearing housing transmission- usually used on small blocks).
Re: 4 Speed and bell housing question [Re: crocha617] #980865
04/27/11 08:24 AM
04/27/11 08:24 AM
Sydney NSW
Sydney NSW
Thanks for the info so far. The number on the retainer is C-15397, then a space of about 2 inches and then a stamped GJ3.
I have another box (apparantely not in operable condition) with retainer number C 13157.
Can the retainer be turned down to suit the small block bellhousing?
Thanks..Rodsports
Re: 4 Speed and bell housing question [Re: Rodsports] #980866
04/27/11 09:48 AM
04/27/11 09:48 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
C-15397 is the GM version of the A833 overdrive. Should have a 10 spline input.
C-13157 is the mopar version of the overdrive. 23 spline input shaft.
You can't machine all the extra off the retainer, machine it down to 4.805" and machine the bell to 4.807".
Dan
FAX 937-947-4419
Re: 4 Speed and bell housing question [Re: 64dodge572] #980867
04/27/11 04:58 PM
04/27/11 04:58 PM
Sydney NSW
Sydney NSW
Dan, Thanks Mate, I appreciate the info and help.
