Re: new lower ball joints worn out in 4000 miles? [Re: jbc426] #98011
08/01/08 11:45 PM
08/01/08 11:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I just stumbled across this information on the differences etween MOOG and the Just Suspension ball joints over on the Slantsix. org page. Interesting reading. You'll have to copy and paste I think.....http://www.cbodydrydock.com/content.php?article.20
I would not believe that crap.
Re: new lower ball joints worn out in 4000 miles? [Re: jbc426] #98012
08/02/08 02:35 AM
08/02/08 02:35 AM
united kingdom
beawulf Offline
beawulf  Offline
united kingdom
As I understand it if you raise the car on the front arms that takes up play in the lower ball joint you can have up to 50 tho play in these joints ( like the old VW beetle ones ) if you have the car with the front arms hanging free you will get lots of movement and think your ball joints are shot in the UK we have to have an MOT every year that includes front end inspection lights rust all sorts of things including a brake test and many inspectors fail my Barracuda on lower balls until I show them the correct way to test them acording to the workshop book hope this helps
Re: new lower ball joints worn out in 4000 miles? [Re: beawulf] #98013
08/02/08 03:14 AM
08/02/08 03:14 AM
West Coast, USA
jbc426 Offline OP
jbc426  Offline OP
West Coast, USA
Intersting! I'll check them both ways in the morning. It could explain why I could not duplicate the looseness that I saw when the car was on the shop's rack.
