Does Dynamat make a big difference? #979839
04/24/11 10:02 PM
04/24/11 10:02 PM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
Is the Dynamat worth the money? How about the cheap stuff on ebay? Is the thicker stuff worth the extra cash? My big block b body with flowmasters is really loud inside. Thanks for the help.
Re: Does Dynamat make a big difference? [Re: Coronet-R/T-Rag] #979840
04/24/11 10:33 PM
04/24/11 10:33 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The stuff is absolutely worth it.. Did a whole car in it. Doors, roof, firewall.. Vast , out of the ballpark difference.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Does Dynamat make a big difference? [Re: sunroofgtx] #979841
04/24/11 10:44 PM
04/24/11 10:44 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How much weight do you think that added?
Re: Does Dynamat make a big difference? [Re: sunroofgtx] #979842
04/24/11 11:28 PM
04/24/11 11:28 PM
Mid Michigan
Mid Michigan
Wow! Nice install. how many square feet did you use?
Re: Does Dynamat make a big difference? [Re: Coronet-R/T-Rag] #979843
04/25/11 12:20 AM
04/25/11 12:20 AM
Renton Washington
Triple Threat Offline
Renton Washington
There's a few different types out there. Some are asphalt based. Some more expensive ones aren't. They certainly do help, but they add weight.
http://www.sounddeadenershowdown.com/
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Does Dynamat make a big difference? [Re: Triple Threat] #979844
04/25/11 12:44 AM
04/25/11 12:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think the Boom Mat is cheaper on price ... either
way you would be better off getting some nice muffs
Re: Does Dynamat make a big difference? [Re: sunroofgtx] #979845
04/26/11 10:52 AM
04/26/11 10:52 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
Have to agree. It is absolutely worth it. I did my 72 cuda 528 hemi similarly. I did the firewall, doors, quarters, rear shelf and under the rear seat. Only thing not done is the roof and floor pan under front carpet. The difference was amazing.
Re: Does Dynamat make a big difference? [Re: cudaboone] #979846
04/26/11 11:21 AM
04/26/11 11:21 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I think it is worth the effort. I used FatMat only because it is quite a bit cheaper. Either way, you love the results.
Re: Does Dynamat make a big difference? [Re: babarracuda] #979847
04/26/11 12:02 PM
04/26/11 12:02 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I used Hushmat and very happy with the results as well.
Re: Does Dynamat make a big difference? [Re: OzHemi] #979848
04/26/11 01:05 PM
04/26/11 01:05 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
When done right, the difference is nothing short of amazing!
You can get bulk packs of Dynamat Extreme for half the list price with free shipping from Amazon dot com. You actually don't have to cover the entire surface of the metal for it to be effective either. I learned this from sites regarding installing it on aircraft, where keeping weight down is at a premium. Tap on the surface before, and some strips of Dynamat and tap on it again. If it is still resonating add more strips a few inces away. Once the resonation is cut down, layer some "insulator" material over the entire area and replace the panel, carpet, etc. Be sure to seal the seams with aluminized tape. It will take car of the remaining sound, noise, heat and fumes.
The perfomance and cost effectiveness of this "insulator" material is incredible and there is currently nothing like it available in the auto industy. It's an aircraft product....great stuff! Check it out. I use the thinner double foiled stuff on everything but the floor, which gets the thicker double sided foil. Cut to fit like a dressmaker pattern and tape up the seams. It's easy to remove later on too.
http://www.aircraftspruce.com/catalog/appages/insulator.php
I used Dynamat on the underside of the roof and added the "insulator" material, which I glued on top of it. The headliner still fit perfectly. The difference in sound between tapping on the roof with and without this treatment is huge. Be thoughful about where you put the stuff when it comes to critical attaching points for trim etc.
Re: Does Dynamat make a big difference? [Re: OzHemi] #979849
04/26/11 01:08 PM
04/26/11 01:08 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
I used FatMat as well. Seems to help although I never had my car on the road without it to compare.
Everything sounds solid when they close and no complaints so far.
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Does Dynamat make a big difference? [Re: HitIt] #979850
04/26/11 01:31 PM
04/26/11 01:31 PM
GA
Boosted Offline
Boosted  Offline
GA
I went to Lowes and bought 3 rolls of the wall insulation. A few cans of carpet glue and it is done...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Does Dynamat make a big difference? [Re: HitIt] #979851
04/26/11 01:39 PM
04/26/11 01:39 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
It makes a huge difference! I used fat mat as well.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Does Dynamat make a big difference? [Re: blown340] #979852
04/26/11 09:44 PM
04/26/11 09:44 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
my setup was similar, summit racing has their own brand at a decent price.
By FAR the biggest difference for me was good factory hood pad. even after the rest of interior was complete.
Re: Does Dynamat make a big difference? [Re: hemibeep] #979853
04/26/11 09:51 PM
04/26/11 09:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Big difference for sure, underhood insulation. Made a huge difference.
Re: Does Dynamat make a big difference? [Re: Challenger 1] #979854
04/26/11 10:15 PM
04/26/11 10:15 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Well, you guys might laugh but I've been re-searching this stuff lately and I found on a "Rat Rod" web site that alot of people were complaining about the price of the Dynamat and Fat Mat and the others. One guy said he went to Lowe's and bought what they call "PEAL AND SEAL". Its used for house roof's and has the foil back on it just like the others. A roll is 4in's X 25ft and is $16.00! Its Super sticky and is about .035 thick. Im going to try it and see if it works.
Plus, they had a roll of foil "bubble wrap" stuff too. Its used in Air Cond. & heat runs to help insulate. Im going to use that under the carpet too.
Figured this was all worth a try. I had something like $50.00 into two rolls of peal and seal and the bubble wrap stuff.
I;ll let you guys know and take some pic's when I get a chance to install it.
Re: Does Dynamat make a big difference? [Re: High Impact] #979855
04/26/11 10:24 PM
04/26/11 10:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
A lot of the guys in my area have used the Lowes foil faced bubble insulation including me. Sealed the gaps with foil tape made for household heating duct. Total cost was $26. I am not going to use it on the hood though.
Craig
Re: Does Dynamat make a big difference? [Re: High Impact] #979856
04/26/11 10:35 PM
04/26/11 10:35 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Pretty sure this is what I used. Bought it at a swap meet. No name stuff. The top aluminum layer can peel off as well. I love it.. I will be doing the GTX in it when we install the 5 speed and OEM carpeting. Not sure on the area inches used. Sorry. I was not worried about weight, just quietness.. Thanks for the kind words.
Re: Does Dynamat make a big difference? [Re: High Impact] #979857
04/26/11 11:37 PM
04/26/11 11:37 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
I've heard about something similar... but I thought people said it reeked of asphalt on hot days?
If it doesn't stink, it seems like it would be a great cheap solution.
Re: Does Dynamat make a big difference? [Re: hooziewhatsit] #979858
04/26/11 11:45 PM
04/26/11 11:45 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Quick question. I put that stuff in my Challenger too. Think the stuff I used was called BrownBread. Its just like the Fatmat; asphalt based, adhesive backed, foil topped. Question is, how do you REMOVE the stuff if doing a rotissere resto. Has anyone done that yet. HOPE it's not stuck down as well as it seemed when installing. I plan on stripping my turn and having the bodywork and paint redone.
