Re: challenger bumper bracket -change years???
[Re: cudasam]
#97988
08/01/08 11:06 AM
08/01/08 11:06 AM
Posts: 4,325 St. Louis, Mo
318 Stroker
St. Louis, Mo
I did it to my 73 Challenger. For the rear, you'll need the thin metal filler from 70-72's, the two small vertical bumperettes to replace the huge 73 guards, & you'll need to remove the "V" shaped license bracket. The front is much easier. 70-72 style brackets, rubber wedges for the bumper corners, & possibly a new license bracket. Keep in mind that the earlier bumpers used a jack hook which lifted from under the bumper, while your jack has a tab that goes in a slot on the bumpers.
