A833 Linkage Rods help
#979681
04/24/11 07:06 PM
04/24/11 07:06 PM
Posts: 1,300 Washington
19cuda73
Washington
I was hooking up the linkage rods today (dont laugh at my attach clips they are only temporary) and I can get the shifter to go through all the fwd gears but I cannot get the reverse shifter plate to move all the way aft. Does anyone have a solution for this with out taking off the cover?
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: A833 Linkage Rods help
[Re: In_The_Pink]
#979684
04/24/11 09:53 PM
04/24/11 09:53 PM
19cuda73
Washington
I will turn the other adjuster for 1st/2nd around. Thanks my assembly manual was not real clear for the direction.
Reverse Rod length can be adjusted but its like the gear inside the transmission is binding.
[Re: 19cuda73]
#979685
04/24/11 10:01 PM
04/24/11 10:01 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Try spinning the tranny while trying to shift, it could be that the clearence is so tight that it doesn't want to mesh.
Careful, your character's showing!
