Main caps R/B & B block #979607
04/24/11 04:08 PM
04/24/11 04:08 PM
Central Pa. U.S.A.
Bigfury Offline OP
Bigfury  Offline OP
Central Pa. U.S.A.
Trying to build a 470 low deck on a shoe string.A fellow mopart has billet mains to sell for a RB block.Would like to know if there is any differences in using them in a B block? Other then the factthe block will need lined bored.
Thanks in advance.
Re: Main caps R/B & B block [Re: Bigfury] #979608
04/24/11 05:41 PM
04/24/11 05:41 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Main bearing size is different from B to RB...so no worky.
Re: Main caps R/B & B block [Re: Bigfury] #979609
04/24/11 05:42 PM
04/24/11 05:42 PM
they're different
Re: Main caps R/B & B block [Re: RapidRobert] #979610
04/24/11 09:00 PM
04/24/11 09:00 PM
IN
ahy Offline
ahy  Offline
IN
As set of studs with stock main caps works well... a light hone recommended after installing and torquing the caps.
