Challenger Convertible Top Help #979478
04/24/11 02:08 PM
04/24/11 02:08 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
First time for me...sure could use some advice on how to properly remove the top assembly. Looks like it will come out all together. I'm still stuck at how to get the chrome off. got the seats out...the qtr trim panels off and everything exposed. Now it is as clear as mud!
by the way...tthis is a 1971 challenger
Re: Challenger Convertible Top Help [Re: scoutsr2] #979479
04/24/11 03:44 PM
04/24/11 03:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The chrome comes off much later... Get into the back seat area, remove the well liner.. There will be a series of bolts with special washers.. Remove those & the top fabric will come free from the body... now remove the rear trim panels (they would be door panels but) behind the panels you'll see the top cylinders are retained by a bracket & a clevis pin.. Disconnect them & leave them with the car, or remove them with the pump & lines as an assembly... Now you'll want to notice there are two 1/2" holes in each side of the top frame which lines up with holes in the body.. these are so you can line the top assembly back up easily.. Loosen the bottom bolt a couple turns & remove the other two bolts per side, then lift the top off the car... Easy..
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979480
04/24/11 04:34 PM
04/24/11 04:34 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Before you unbolt it from the car, I would some how make some marks in the car so when you put it back together it will be much easyer to get it in the right spot.
Re: Challenger Convertible Top Help [Re: Darryls-Demon] #979481
04/24/11 04:55 PM
04/24/11 04:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As I mentioned in my post, there are two 1/2" holes on each side through the top frame and the body structure or the car so realignment is easy... Just put a couple 1/2" rods through the alignment holes & tighten the bolts securing the top then remove the alignment rods..
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979482
04/24/11 05:09 PM
04/24/11 05:09 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
I don't see the bolts for the top well...should I have the top in the up or down position for this process? thanks for the guidance!
Re: Challenger Convertible Top Help [Re: scoutsr2] #979483
04/24/11 05:24 PM
04/24/11 05:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Top up while removing the well liner & bolts... Top down after that...BTW the well liner is the black vinyl liner behind the seat, it is glued to the seat brace & it snaps to clips attached around the convertible top well...
Re: Challenger Convertible Top Help [Re: scoutsr2] #979484
04/24/11 06:34 PM
04/24/11 06:34 PM
BC
70RT27N Offline
70RT27N  Offline
BC
With the top up and the well liner off, you should see these bolts and the aluminum bar they hold in place...
Re: Challenger Convertible Top Help [Re: 70RT27N] #979485
04/24/11 06:52 PM
04/24/11 06:52 PM
BC
70RT27N Offline
70RT27N  Offline
BC
Here is the top lift mechanism. You can see two bolts on the left, and there should be another bolt that is hidden, about 7 inches to the right of the top bolt.
Re: Challenger Convertible Top Help [Re: 70RT27N] #979486
04/24/11 10:36 PM
04/24/11 10:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That car hasn't been messed with much, still has the rubber plug in the alignment hole.... The third bolt is accessed through the hole in the top mechanism & the bar holding the top in the previous photo isn't aluminum it's a galvanized channel with a dense cardboard material filler the top is stapled to that filler material....
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979487
04/24/11 11:56 PM
04/24/11 11:56 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
thanks for all the help! I got it off and now I can see what was previously hidden. Not as bad as I thought it would be but now I get to try and figure out how to fix it. [image]http://[/image]
Re: Challenger Convertible Top Help [Re: scoutsr2] #979488
04/25/11 12:00 AM
04/25/11 12:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well it's purple.... Looks like you have some work to do....
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979489
04/25/11 12:16 AM
04/25/11 12:16 AM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
would love to see more pics of your car... I have a long ways to go. I have a 6.1 Hemi going in mine and planning to run alterkation front and probably their rear. A challenger convertible has been my dream car for a long time and i am really stoked about building it. Still have finishing details on my Charger but cant get motivated on it with the challenger in the mix.
Re: Challenger Convertible Top Help [Re: scoutsr2] #979490
04/25/11 12:31 AM
04/25/11 12:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well just to motivate you hows this...
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979491
04/25/11 12:35 AM
04/25/11 12:35 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This came later...
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979492
04/25/11 03:27 AM
04/25/11 03:27 AM
Knights Ferry, CA
X
XDMN Offline
XDMN  Offline
X
Knights Ferry, CA
Wow, look at that hair.
Bill Adams
69 RR convert Petty Blue
68 Dart post
55 DeSoto Fireflite Sportsman
60 New Yorker
62 300H
65 300L
Re: Challenger Convertible Top Help [Re: XDMN] #979493
04/25/11 04:12 AM
04/25/11 04:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah Yeah... Just wait...
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979494
04/25/11 01:17 PM
04/25/11 01:17 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Wow! A Challenger convertible bobtail edition. So did you find a donor car or did you fabricate a bunch a stuff? Can't imagine anybody offers that channel thats rusted out on mine...
Very nice by the way....
there is a hard top sublime 70rt down the road a ways that I tried to get my hands on for years with no luck. Every time I see it there are more and more parts missing
Re: Challenger Convertible Top Help [Re: scoutsr2] #979495
04/25/11 01:24 PM
04/25/11 01:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You'll need to fab the drain channel & likely the plate behind it that the top bolts to... I was lucky on my car, it came with a with hard top quarter, I already had saved a top section from a convertible knowing this car needed one, just didn't know it I'd ever get a shot at the car as the owner didn't want to sell it...
More about it here.. http://www.moparts.org/moparts/picture/print/pages/Reddig.html
Re: Challenger Convertible Top Help [Re: 1_WILD_RT] #979496
04/25/11 02:26 PM
04/25/11 02:26 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
What a cool story...
I kind of lucked in to mine. A Challenger convertible had been a dream car of mine for many years and I actually blew a chance at one about 15 years ago over price. The same price by the way for a finished car that I later paid for this project! I host an all Mopar Muscle car show here at the dealership every year and two years ago a guy from eastern New Mexico called the store looking for the fellow that puts that show on. I told him that he had the right guy and as we got to talking I relaized who he was and that he had shown up to our show with a 340 4Speed Challenger on a trailer for sale but left before one of my friends could see it. I asked him about it and he said it had sold already...I asked if he had anything else for sale and he says...well, I have a couple Challenger Convertibles I would like to get rid of... and my jaw dropped. Obviously I ended up with it. Original 318 plum crazy purple. I got the original engine and trans but a 318??? naahhh!
By the way, the show I am talking about is coming around again May21st if anyone wat to comeout for some good BBQ and a bunch of good ole Mopar fans
Re: Challenger Convertible Top Help [Re: scoutsr2] #979497
04/25/11 05:35 PM
04/25/11 05:35 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I found my Challenger vert from a spam email about some Mopars for sale in town.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
