BPE 4.250" Crank/OEM Block #979351
04/24/11 10:25 AM
04/24/11 10:25 AM
BPE Offline OP
BPE  Offline OP
I've had several questions concerning clearance issues that
may be encountered using the BPE 4.250" stroke crank. I mocked
one up in a +.030" 340 block using both the Compstar 6.200" and
Oliver 6.200" rod.
A mile to the pan rail.
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979352
04/24/11 10:28 AM
04/24/11 10:28 AM
BPE Offline OP
BPE  Offline OP
Compstar rod will require minimal clearancing at the bottom of the bore(4.070") for rod bolt.
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979353
04/24/11 10:29 AM
04/24/11 10:29 AM
BPE Offline OP
BPE  Offline OP
As does the Oliver.
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979354
04/24/11 10:33 AM
04/24/11 10:33 AM
BPE Offline OP
BPE  Offline OP
Clearance to the oil pump and Milodon pick-up was checked with both
rods in standard and HV Melling 72 oil pumps. Over .100" in all instances.
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979355
04/24/11 10:36 AM
04/24/11 10:36 AM
BPE Offline OP
BPE  Offline OP
Not a concern with this block but, something else to check for.......to the dipstick boss.
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979356
04/24/11 11:07 AM
04/24/11 11:07 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Thanks for the post & pics !!
Re: BPE 4.250" Crank/OEM Block [Re: DavidDean] #979357
04/24/11 11:08 AM
04/24/11 11:08 AM
Q
Quicktree Offline
Quicktree  Offline
Q
good tech be interesting how long a stock block lasted and what kind of power it made with that crank.
Re: BPE 4.250" Crank/OEM Block [Re: Quicktree] #979358
04/24/11 11:27 AM
04/24/11 11:27 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Looks like a lot less clearancing than I needed to get a 3.55 aluminum rod crank in a 318!!
Speaking of which, I'm thinking about using the 4.25 as a torque monster in a 318 block (since I already have one) Something with about 525 lb/ft at 3200 rpm to use as a tow rig.
WIZE
In Car:
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979359
04/24/11 11:55 AM
04/24/11 11:55 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
That looks great!!
I can see 1 of these combos in my future!!
Thanks again for trying to make the S/B market affordable, but still quality!
Re: BPE 4.250" Crank/OEM Block [Re: Quicktree] #979360
04/24/11 12:28 PM
04/24/11 12:28 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Rod insisted on checking clearances in a stock block.
We could have used my R-block but, he wanted to show
what the average guy might have to work around.
Re: BPE 4.250" Crank/OEM Block [Re: S/ST 3040] #979361
04/24/11 12:46 PM
04/24/11 12:46 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Vic,
What are you waiting for? put one in your R block and go fast.You told me you could not find a decent stock crankshaft anyway.
Just
Let me know if you still need a crank and I will make some calls on Monday.
Keith
Re: BPE 4.250" Crank/OEM Block [Re: S/ST 3040] #979362
04/24/11 12:56 PM
04/24/11 12:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I understand, but I was wondering how the stock block would hold up under the extra stroke. build one and let us know.
Re: BPE 4.250" Crank/OEM Block [Re: Quicktree] #979363
04/24/11 01:10 PM
04/24/11 01:10 PM
Northern Indiana
Northern Indiana
I would not be too concerned with a stock block,properly prepared and depending on it's use.My 4.125 BPE crankshaft is in a stock 360 block and has been being abused for a long time with no issues.
I run mine to 6500 every pass,and used to wind it to 7000.People worry about longevity but how many of us would run something like this for 100,000 miles anyway?
Big block guys run strokes this big or bigger all the time.The lightweight parts that tend to go with the longer strokes really help IMO.
Just my
Keith
Re: BPE 4.250" Crank/OEM Block [Re: Dunnuck Racing] #979364
04/24/11 01:26 PM
04/24/11 01:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Just my
Keith
Re: BPE 4.250" Crank/OEM Block [Re: Dunnuck Racing] #979365
04/24/11 01:33 PM
04/24/11 01:33 PM
S/ST 3040 Offline
S/ST 3040  Offline
I filled your block.
I wouldn't hesitate to build a stroked SB that sonic checked good though.
BTW, the problem I'm having finding a stock crank is, all of them
are .010"/.010", .010"/.020", etc. H-bearings are only available
in standard or .010" and I'm too picky with my clearances to buy
one already "turned".
That or they want stupid money for them.
Re: BPE 4.250" Crank/OEM Block [Re: Quicktree] #979366
04/24/11 01:48 PM
04/24/11 01:48 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I would not anticipate any issues with steel rods on that crank. A little nip in the bottom of the cylinders and you should be fine. Be careful not to cut into water getting greedy with the grinder. Guys need to remember though, a stock 340 4.040" bore. A 318 is only 3.910". The diiference in bore .130". You only need to know half of that .065" when clearancing. This should not be an issue, but something to keep in mind. And unless you plan to run with bent rods or worn out bearings .015 is all the clearance you need.
Something else I have ran into big differences in rod length can change cause a clearance issue if you were already really close.
I have heard people cringe at the XR2 blocks worried about the cam tunnel. I wouldn't get too exited as it is nowhere close on an A engine block.
I have run BIG alluminum rods in the past and the internal oil pump was the only item that took extra work to clearance. Would run an external in the future on any build like this.
Now if someone wants to give away a XR2 with the lifters done and no oil leaks I will be glad to show you how a back yard hillbilly can make a huge engine on the cheap. LOL
Leon
Re: BPE 4.250" Crank/OEM Block [Re: S/ST 3040] #979367
04/24/11 03:10 PM
04/24/11 03:10 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I
cant even find a stock forged 273 or 318 crank for good money? everytime i dont need one i seem to run into them in piles,its a shame i could have had a whole pallet of those cranks stached away for no money at all by now i think 318 poly engines have good cranks aswell.
Re: BPE 4.250" Crank/OEM Block [Re: 1Fast340] #979368
04/24/11 04:13 PM
04/24/11 04:13 PM
ohio
all spooled up Offline
ohio
rod do you have a list of compression hight on your pistons ??
i like to get a 4.125 or 4.250 crank i all ready have a set of 6.300 h beam rods 2.000 b end .927 s end
Re: BPE 4.250" Crank/OEM Block [Re: all spooled up] #979369
04/24/11 08:22 PM
04/24/11 08:22 PM
BPE Offline OP
BPE  Offline OP
There really isn't a specific compression height on the pistons I offer. What I do is have pistons made for your build. After the engineering costs we only need to stay within a few perameters. I currently offer a -17cc dish and a flattop for the 4.125". We can adjust for rod length, deck height, bore size, ect. So, it's like getting a custom piston without all of the costs associated with it. We are currently working on the 4.250" stroke combo's.
Rod
Re: BPE 4.250" Crank/OEM Block [Re: BPE] #979370
04/24/11 08:34 PM
04/24/11 08:34 PM
ohio
ohio
thanks
