which harmonic damper?? #978902
04/23/11 04:06 PM
04/23/11 04:06 PM
eastern long island,NY
JeepJimmy Offline OP
87 dakota 3.9. swapping a 96 magnum 318, going to use the old style timing cover and V belt setup. which harmonic balancer will i need to use. will the 3.9 one work?
70 duster 360magnum, 1975 jeep j-10.
Re: which harmonic damper?? [Re: JeepJimmy] #978903
04/23/11 10:02 PM
04/23/11 10:02 PM
would the 0ld premagnum 3.9 be balanced the same as a 318 magnum. both internal..
Re: which harmonic damper?? [Re: JeepJimmy] #978904
04/25/11 07:39 PM
04/25/11 07:39 PM
any ideas?
