Re: Cost to replace Head Gaskets (383)
[Re: c5ryan]
#978759
04/23/11 01:55 PM
04/23/11 01:55 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Doing work at home I wouldnt even get my tools dirty for $25 an hour.I agree the price is reasonable.Id also have a valve job done when the heads are off.If they havent been done now is the time.That and replace the valve seals if they are older.The parts must be what they cost as FelPro 1009s are about 80 bucks a set and then 25 for the intake gasket and another 20 for good valve cover gaskets.Rocky
Chrysler Firepower
[Re: therocks]
#978760
04/23/11 02:02 PM
04/23/11 02:02 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
No way in he** I'd do it for that... If you trust him, let him do it... But if your smart you'll have the heads taken to a machine shop, checked for cracks & a light surface cut taken... Wait, I just doubled the cost...
[Re: 1_WILD_RT]
#978762
04/23/11 09:18 PM
04/23/11 09:18 PM
Posts: 21,485 It's a dry heat
gtx6970
It's a dry heat
ditto
[Re: Jeremiah]
#978764
04/23/11 11:21 PM
04/23/11 11:21 PM
Posts: 394 md
wicked
md
How do you know it has a blown head gasket?
I'd be skeptical of any show that would say "sure we'll change the head gasket for $xxx" without wanting to know WHY it has coolant in the oil first.
Good luck!
X2 , I would be looking for "why" also
[Re: Junky]
#978766
04/24/11 10:57 AM
04/24/11 10:57 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
hate to say it but you need to tear it down and investigate first. not just blindly go in and swap head gaskets.
how do you know it's a head gasket? what if you have a cracked head? what if it's a cracked block?
I had a cracked cylinder wall, and its the same problem as a head gasket--water in the oil, steam out the exhaust, etc.
that was a $100 sleeve job to fix...and a full tear down of the motor, which means you also need a full gasket kit, and why not toss new bearings and rings at it while you have it down to a bare block?
then when you sell the car, you can say the engine was recently overhauled/rebuilt.
**Photobucket sucks**
[Re: 70Cuda383]
#978767
04/24/11 03:20 PM
04/24/11 03:20 PM
Posts: 227 upstate NY 12839
TMBOOTS
upstate NY 12839
Got to agree with the Kaptain!!! I found some hairline cracks in my block when I pulled my intake off..Never know what your going to find.
[Re: c5ryan]
#978768
04/25/11 06:16 AM
04/25/11 06:16 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
Was the engine overheated recently???
I agree, a proper diagnosis and teardown should be done if not already, then you'll know what you're up against.
You could have a cracked head or maybe just a blown intake gasket.
Tearing down and old Mopar is easy and fun. All you'd need for special tools would be a torque wrench. You don't even have to pull the distributor and mess with the timing.
[Re: Dean_Kuzluzski]
#978769
04/27/11 12:16 PM
04/27/11 12:16 PM
Posts: 9 NC
c5ryan
NC
Update.... My brother is actually a mechanic and opened his own shop (and dealership) a couple weeks but they usually turn quicker jobs. The person/shop they outsource major jobs to said it would cost $200 in labor and I can pickp the parts on my brother's dealer acounts at napa or advance. They are closer so I may just go this route, as I feel a lot safer changing the oil and running it 8 miles than making a 40 mile trip or having to rent a trailer or have it flat bedded.
I have no idea if its the head gasket, I just assumed it was the most likely source. This is where you would start anyways right, looking at head gasket and head?
To answer the other question, I guess it depends on what the line is on overheating. When I got the car it ran up to ~230deg (?), its hard to remember, I think it got up to 215-220 and I got scared and cut it off, then it ran up higher sitting. It had a 195 thermostat, a reverse rotation fan, and some small coolent links, it would stay at 195 on the highway but heat up in traffic. I put in a 160 thermostat, a regular flex fan, and got the coolent pressureized correctly.
I'm not sure if this helps but I think it may have lost coolent into the engine while the car was sitting overwinter. I pretty regularly check the level and I'm fairly sure it would have been full when I was driving it last summer. First time I cranked it up this spring I had to add a inch or two.
