How do I block the exhaust cross-over? #978478
04/23/11 12:52 AM
04/23/11 12:52 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
If my valley pan has the full opening for the heat cross-over can I block it somehow (without buying a new valley pan)?
Re: How do I block the exhaust cross-over? [Re: VITC_GTX] #978479
04/23/11 01:16 AM
04/23/11 01:16 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
SOME have suggested that you melt some old pistons and fill the crossover in the intake with the molten aluminum.
NEVER done that me-self ...I am a fan of a crossover at least a LITTLE open.
Re: How do I block the exhaust cross-over? [Re: dOc …] #978480
04/23/11 01:39 AM
04/23/11 01:39 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Yeah I hear ya but I have a very old Torker 383 intake that has a crossover (didn't think they had them...) that I want to close up.
This intake has a hole in the bottom of the plenum that goes into the heat cross over and there is, what appears to be, a provision for a choke or something directly behind the carb. I wanted to close it up.
Re: How do I block the exhaust cross-over? [Re: VITC_GTX] #978481
04/23/11 07:34 AM
04/23/11 07:34 AM
Truckville, the capital of NY
85_Ram_4speed Offline
Just find some thin sheet metal and cut out a couple rectangles bigger than the crossover opening in the head. I get a lttle more extragevent and have a tiny tab on the end of the plate i bend to 90 degrees so it holds in place better while putting the intake gaskets on. Just use a little silicon to hold them onto the head, and put your intake gaskets over that. Done. I do this to any engine I do that wont see any cold weather use. If you email me, I can send you a pic when I cut a set for a 383 and 440 I am getting ready to button up here.
If your after just filling the hole in the bottom of the intake, A little JB weld will hold just fine there if the surface is clean--i would get some aluminum cleaner---BUT, you still need to block it off at the heads as it will blow the JB weld back out eventually.
Outcast Dodge guy.
Re: How do I block the exhaust cross-over? [Re: 85_Ram_4speed] #978482
04/23/11 12:53 PM
04/23/11 12:53 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Cut a couple of pieces from a old valley pan and make some block offs and secure them with ultra copper rtv.
Re: How do I block the exhaust cross-over? [Re: Y3 70 BEE] #978483
04/23/11 01:00 PM
04/23/11 01:00 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
It has GOT TO BE some real thin sheet metal. If not .. it can screw-up the seal of the intake to head. I have heard of some people having good-luck with some hi-quality stainless steel.
Re: How do I block the exhaust cross-over? [Re: VITC_GTX] #978484
04/23/11 02:23 PM
04/23/11 02:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I did have some of FelPro block offs laying aroud here.Dont know if I can find them but if I do Ill send them to you.I always just buy the pan with the blocks.Rocky
Chrysler Firepower
Re: How do I block the exhaust cross-over? [Re: therocks] #978485
04/23/11 05:00 PM
04/23/11 05:00 PM
Under My Car
Mopar_Country Offline
Under My Car
I use roof flashing, very thin and seems to hold up.
Re: How do I block the exhaust cross-over? [Re: Mopar_Country] #978486
04/23/11 06:26 PM
04/23/11 06:26 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i cut out some sheet aluminum and welded it into openings in the aluminum manifold.
then milled the welds down flush
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: How do I block the exhaust cross-over? [Re: aarcuda] #978487
04/23/11 06:54 PM
04/23/11 06:54 PM
houston texas
gremlinsteve Offline
houston texas
a roll of aluminum foil. tear of sheets of it and pack it in..keep going until your satisfied with it.
it works btw and is a older way of doing it....
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: How do I block the exhaust cross-over? [Re: gremlinsteve] #978488
04/23/11 08:18 PM
04/23/11 08:18 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
At one time I used stainless shim stock. Don't remember the thickness, but months later it was same as when it when in. I don't know how to tune an engine very good and I couldn't make my engine run right with it blocked (I'm sure because the temps and mixture didn't get along) so I unblocked it.
Re: How do I block the exhaust cross-over? [Re: VITC_GTX] #978489
04/24/11 12:12 AM
04/24/11 12:12 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks to all for the good tips.
Rocky- Thanks for the offer to send the block offs!
I think I'll just cut some thin stock and lay them in there. Or maybe's Steve's idea of tin foil
Re: How do I block the exhaust cross-over? [Re: VITC_GTX] #978490
04/24/11 12:58 AM
04/24/11 12:58 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Why not just buy the $20.00 block off vally pan.
To do any other block off option , you will have to remove the intake anyways and want a new pan gasket.
The Tin foil plug is a old school idea. I did that back in 1976 It didnt last though
Maybe I didnt cram the tin foil balls in there hard enough. After a year, when I took the intake off, all of the tin foil was gone
The forces of exhuast pressures and heat were enough to remove the tin foil restriction over time.
Re: How do I block the exhaust cross-over? [Re: Sport440] #978491
04/24/11 01:29 AM
04/24/11 01:29 AM
houston texas
houston texas
ya gotta use alot of it i know. its gonna take up alot of that roll.
just a suggestion
Re: How do I block the exhaust cross-over? [Re: gremlinsteve] #978492
04/24/11 08:27 AM
04/24/11 08:27 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I also unblocked mine on the GTX to get the stock AVS carburator choke to open correctly. It gets a little hotter but working OK.
