K member tech- what do I have here? #977724
04/21/11 10:43 PM
04/21/11 10:43 PM
Portland , Oregon, United Stat...
smokes Offline OP
smokes  Offline OP
So I just bought a 68 Post Coronet and also bought a k member with disc brakes attatched to them. I know it's factory chrysler but the guy said it was an ebody and that it would be the same and work. I just read the other post about the ebody k member and that the steering was different. I pulled the numbers off the motor mount and was wondering what I have? They where not the greatest stampin but I was able to read MK34631 or MK84631. I measured the rear mounting holes and they measured just under 34 inches. From the right rear mounting hole to the left front hole it measured 36 1/2. Both of these where measured from center to center.
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: K member tech- what do I have here? [Re: smokes] #977725
04/21/11 11:11 PM
04/21/11 11:11 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
I think you need to look at the front lip of the K frame to see if it has the holes to mount the sway bar. There should be two holes on each side if it's a '69 & before.
Re: K member tech- what do I have here? [Re: gregn96cuda] #977726
04/22/11 12:52 AM
04/22/11 12:52 AM
smokes Offline OP
smokes  Offline OP
I looked at the k member and no holes in the front of it. It also does not have the center hole for the sway bar to pass through either. I am pretty sure my 69 charger I had did not have the front mounting holes either. Are the numbers on the left front engine mount the ones I need to look at to id it correctly?
Re: K member tech- what do I have here? [Re: smokes] #977727
04/22/11 01:20 AM
04/22/11 01:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
If it doesn't have the provisions for the pass-thru sway bar - then it isn't e-body.
The motor mounts are not body dependant.
Single piston calipers? Are you sure it isn't a-body?
Re: K member tech- what do I have here? [Re: 6bblgt] #977728
04/22/11 02:01 AM
04/22/11 02:01 AM
smokes Offline OP
smokes  Offline OP
I was referencing the mount as that was the only thing that I saw that had numbers on it. Is that the only spot on a k member that has numbers on it? I will have to look at the calipers and pull some numbers off them. I am pretty sure they are kelsey hayes. I don't think that it's an a body as the guy say it was off a chally and he didnt really do any thing with a bodyies. Only 2 cars out of about 20 where a body. Everything else was e body or b body. I will have to post some pics if that helps you guys.
Re: K member tech- what do I have here? [Re: smokes] #977729
04/22/11 07:46 AM
04/22/11 07:46 AM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
pictures please!
Re: K member tech- what do I have here? [Re: BigTerry] #977730
04/22/11 11:57 AM
04/22/11 11:57 AM
smokes Offline OP
smokes  Offline OP
I will post some tonight!
Re: K member tech- what do I have here? [Re: smokes] #977731
04/23/11 01:06 AM
04/23/11 01:06 AM
smokes Offline OP
smokes  Offline OP
Alright I got some pics- I did look at the k member again and it has the center pass through for the bar for sure, contrary to my previous statements. I did pull some numbers off the single piston calipers and they are kh88188 for the right front and kh86166 for the left front. The caliper brakets number is 09654101 for both.
Re: K member tech- what do I have here? [Re: smokes] #977732
04/23/11 01:08 AM
04/23/11 01:08 AM
smokes Offline OP
smokes  Offline OP
Re: K member tech- what do I have here? [Re: smokes] #977733
04/23/11 03:36 AM
04/23/11 03:36 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The pin-type calipers were used on early 70s B and E bodies (I'm not sure when they changed to slider calipers on B/Es, but the sliders came out in 73 on A-bodies). It is likely that you have an E-body setup there.
Re: K member tech- what do I have here? [Re: Jim_Lusk] #977734
04/23/11 11:26 AM
04/23/11 11:26 AM
smokes Offline OP
smokes  Offline OP
So since I bought this for my coronet big block car I would just need to get a b body big block k member and the contol arms and brakes from this would swap right over because they are the same, correct?
Re: K member tech- what do I have here? [Re: smokes] #977735
04/23/11 12:16 PM
04/23/11 12:16 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Without reading the entire post from what I see you may have a '68 early '69 V8 (non-Hemi) K-frame with the 4-holes (2-each side front) for the '68/'69 swaybar and NO swaybar end/link mounts on the Lower Control Arm (LCA). That is not an E-body K-frame. You need the LCA's with the swaybar mounts and it should work for any V8 Mopar engine of that era.
MikeR
This is the later '69 K-frame that started to change over to the '70 swaybar routing through the K-frame and still has the 4-holes at the front for the '68/'69 swaybar mounting like I think I see in you K-frame photo.
Re: K member tech- what do I have here? [Re: smokes] #977736
04/23/11 12:19 PM
04/23/11 12:19 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Kind of hard to tell exactly, but looking at the rotors...it appears to be from a 70-72 B or E-body. I say that because the rotors look like the 2 piece design.You can buy a spindle sleeve from Dr. Diff so that you can use the later 1 piece rotors that are a LOT cheaper and easy to get. So yes...the brakes will work. If it were me, I would make a way to get both k frames level (both ways)and check the angle of the steering box mount plate. I did that with a 70 Roadrunner k frame and a 70 Challenger k frame a few years ago, and there was 2 degrees difference in the angle of the box. I think the e body was 23 degrees, and the b was 25 degrees. Would that make a difference as far as wearing out steering column joints? People here have used different body style k frames in cars and didn't seem to have problems. Check around some more before you go buy another k frame. No need to worry about it being from a big block as long as it's from a V8 car. Unless it's a Hemi k frame, they will all fit big or small block. The difference is in the brackets that actually bolt to the motor. That's my , so good luck.
Re: K member tech- what do I have here? [Re: A12] #977737
04/23/11 12:28 PM
04/23/11 12:28 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This top mount on the LCA is what you need to put a swaybar on but I can't or don't see it in your photo........from what I know all of the V8 B-body K-frames were the same (except for skid plates on the Hemi for the oil pan??), the engine mounts are different too but you knew that....
MikeR
Re: K member tech- what do I have here? [Re: A12] #977738
04/23/11 12:38 PM
04/23/11 12:38 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Check the K-frame date on the front (see the photo with the text above for the location) that will tell you (roughly) what you have. If it's a xxx8 x number (think in '68 some were stamped upside down too so there's another clue) and you have a fender tag with a Scheduled Production Date and both numbers are close then it's the original K-frame IMO.
MikeR
Re: K member tech- what do I have here? [Re: A12] #977739
04/23/11 05:05 PM
04/23/11 05:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Sorry was in a real rush when I read (re; skimmed) the original post and maybe the date stamp will give you a clue but if it is an E-body as posted the steering box angle will (might??) be a problem. Can you see the production date stamp on it, again sorry for not reading the entire post.
MikeR
Re: K member tech- what do I have here? [Re: A12] #977740
04/23/11 07:53 PM
04/23/11 07:53 PM
smokes Offline OP
smokes  Offline OP
MikeR
I will go home tonight and look at the k member again. I know it is not the original because the original is for a slant 6 the car still has! I bought this extra k member because the guy who I bought the car had it and I got it complete for $200 so I figured even if it was an e body frame I could still sell it and get another. I will look at those numbers tonight and get back to you. It looks like the numbers are on the very front lip of the member.... correct me if I'm wrong. Post up again tonight!
Re: K member tech- what do I have here? [Re: smokes] #977741
04/23/11 11:08 PM
04/23/11 11:08 PM
smokes Offline OP
smokes  Offline OP
So I scoured the k member for new numbers. I did not find anything in the front or the back but I did find some numbers on the top and the bottom. If you are looking down on it from the top right next to that tiny hole in the top of it that is covered by the oil pan it says M 1565. If you are looking up at it right next to where the two sheets of metal meet below the hole up top it says MK45-1 and LMK 45-1. Hope this rings a bell with someone!
Re: K member tech- what do I have here? [Re: smokes] #977742
04/25/11 07:59 PM
04/25/11 07:59 PM
smokes Offline OP
smokes  Offline OP
any help ????
Re: K member tech- what do I have here? [Re: smokes] #977743
04/26/11 12:46 PM
04/26/11 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
any help ????
Yes , that is a 67-to early 69 B body K ... best I can tell from the blurry pictures ... it does appear to have the swaybar mount holes on the front lip ... best I can tell again blurry pictures. Someone swapped on the 70-72 B/E single piston brake setup judging by the rotrs ... 2 piece ??? and the pin type calipers , if so those rottors are hard to find an $$$. I think Dr. Diff sells a spacer so you can use the 73 up unicast rotor on that spindle .
I can't really tell if it's a small/big block or a slant 6 from those pictyures .
