Hey guys,
Needing to replace my fuel tank. Was going to upgrade to a 3/8" sender with the 1/4" return for my beefed up 400. My question is, the car had a vapor canister on it from the factory, but that is done away with. However, the hard fuel line that was used for that setup is still there, just not used. Where does this line go? Also, could I use this line as the return line, if so, what would I need to do? Any other snags I could run into?
Thanks!
Paul
