1969 GTX Trunk Panel #97638
07/31/08 12:36 PM
07/31/08 12:36 PM
Colorado
CaptainGTX Offline OP
Colorado
I was recently told that 1969 GTX's used some kind of gasket material behind the diecast trunk decor panel. I know the speednuts were sealed, but does anyone know if there was another gasket & what it might have been made of? Also, does anyone know a source for the speednuts, which were a different design than used elsewhere on the car?
Re: 1969 GTX Trunk Panel [Re: CaptainGTX] #97639
07/31/08 01:36 PM
07/31/08 01:36 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
The studs which got through the trunk lid had gaskets on each stud. That is the way the NOS panel was I just installed.
performancecarrestorations.com
Re: 1969 GTX Trunk Panel [Re: moparo] #97640
07/31/08 01:47 PM
07/31/08 01:47 PM
Colorado
Colorado
Now that you mention it, mine had little fiber washers too. The former Chrysler employee I recently talked to insinuated it was something larger, but I guess with the stud gaskets, there wouldn't have been any reason for a larger gasket, unless it was just to protect the paint. Thanks for jogging my memory.
Re: 1969 GTX Trunk Panel [Re: CaptainGTX] #97641
08/06/08 09:05 PM
08/06/08 09:05 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I don't remember any gasket on my 69 GTX back then. I removed the one of my preserved 69 GTX and no gasket. Would a gasket not retain water in that area and hasten rusting?
