Page 2 of 3 1 2 3
Re: are thermoquads any good [Re: Mr.Yuck] #975712
04/19/11 03:22 PM
04/19/11 03:22 PM
United states wisconsin
bigblockbryan Offline OP
Well I wiill try the timing again after the carb and I also do have a 3:91 sure grip I can install
Re: are thermoquads any good [Re: bigblockbryan] #975713
04/19/11 03:40 PM
04/19/11 03:40 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
try www.thermoquads.com has some good info on tuning also www.carbkitsource.com will tell you anything you need to know about your carb.
Re: are thermoquads any good [Re: bigblockbryan] #975714
04/19/11 03:46 PM
04/19/11 03:46 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
on the timing, you'll need to change the advance springs in the distributor for lighter springs, so that you have full mechanical advance sooner. you'll want it all in by 2500 or so. then, set the timing advance with the engine actually AT 2500-3000 so that the timing is fully advanced, and you're setting the total advance up around 36-38.
**Photobucket sucks**
Re: are thermoquads any good [Re: 70Cuda383] #975715
04/19/11 05:43 PM
04/19/11 05:43 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
my hero ...
Re: are thermoquads any good [Re: IcorkSOAK] #975716
04/19/11 07:27 PM
04/19/11 07:27 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
I forget the racers name but a pro driver won a NHRA national event with the Thermoquad..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: are thermoquads any good [Re: 72N96RR] #975717
04/19/11 07:51 PM
04/19/11 07:51 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
all small block mopars...71+ that run nhar stock or superstock....HAVE to run Thermoquads...
there are some people who know how to run fast with them...and there are some who dont..
Tony
70 AARCuda Vitamin C
Re: are thermoquads any good [Re: Mr.Yuck] #975718
04/19/11 07:59 PM
04/19/11 07:59 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
A 6139s Thermo-Quad is an excellent model and will work great on your car. This is one I recently restored for a fellow member.
looks good. How about 2 of them on a tunnel ram.....
They work great on a tunnel ram.Dave
Re: are thermoquads any good [Re: Mr.Yuck] #975719
04/19/11 08:03 PM
04/19/11 08:03 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
You can't go wrong w/ a 750DP. The 3.23's are what's going to cause you head-ache with that cam. You are going to drop the hammer at 4500 and it's going to want to fall flat. The DP will be more tunable than the TQ. As mentioned make sure you have your timing set..I'd try all in full 38* at 2400.
The DP is a bit more user-friendly, but
the TQ does produces overall a better torque curve, in comparison. DP's ARE rpm happy, since they can kick the secys in on demand. TQ's create torque, till their secys kick in off of vac. When properly adjusted watch out!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: are thermoquads any good [Re: 72N96RR] #975720
04/19/11 08:32 PM
04/19/11 08:32 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Scott,these work well too!
Actually I agree....A similar carb design in fact, pretty decent piece overall. However I'd choose a TQ over the Rochester for a few reasons, weight being one, fuel temperature being another, and so on.
Re: are thermoquads any good [Re: ScottSmith_Harms] #975721
04/20/11 07:10 AM
04/20/11 07:10 AM
Lexington NC
twinscrew698 Offline
Lexington NC
Scott,Or anyone else that might know!Any idea what this Kit fits?
I believe it is the smaller Secondaries!
Re: are thermoquads any good [Re: twinscrew698] #975722
04/20/11 08:22 AM
04/20/11 08:22 AM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
The kit fits '78-'84 800 and 850 cfm carbs and the bowl is for '78-'84 800 cfm carbs. It can be used on '75-'77 800 cfm carbs(except '75-'77 440 trucks)also and all aftermarket SuperQuad spread bores, David.
Re: are thermoquads any good [Re: 70Cuda383] #975723
04/20/11 01:17 PM
04/20/11 01:17 PM
so were would i go to get springs i have mopar performance distubutor also is there a way to a lock it out from adavancing. Or is that why i need lighter springs i am new to this kinda performance tuning i'm gonna probably try the 750 dp on it see if that makes a diffrence swap in springs.Then move to the gears the run down on the car is its a 1965 plymouth sport fury with 10.1 comp 452 heads i had a valvejob done too elderbrock performer 440 intake 750 elderbrock carb stock outta the box with a mopar performance igition system and a 4 speed with 3.23 gears
Re: are thermoquads any good [Re: DEMONSIZZLER] #975724
04/20/11 04:33 PM
04/20/11 04:33 PM
Lexington NC
Lexington NC
Thanks Dave,Now i know!!!
By the way my TQ is still running GREAT!!
Re: are thermoquads any good [Re: bigblockbryan] #975725
04/20/11 05:34 PM
04/20/11 05:34 PM
Under My Car
Mopar_Country Offline
Under My Car
okay i got a thermoquad on a 71 340 motor when i bought my demon it looks pretty good and suppose to work good anyway would this be a upgrade. Over my 750 eddy i have on top of my 440 the eddys stock in outta the box and my motor has some issues i think its due to my 484 cam lacking fuel im gonna also try a Holley 750 dp my buddy runs on a camaro putting out 507 hp.
Try the Thermoquad, you might be surprised. Ma mopar new what she was doing using it.
I just got mine back together and WooHoo
It's an 850 on top of my built 318 and all I can say is
Re: are thermoquads any good [Re: bigblockbryan] #975726
04/20/11 07:08 PM
04/20/11 07:08 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline
The TQ is hard to beat either way you go the name gives the big secret away. And with some home work you can tune in a mean carb. Fuel runs cooler and which is what thermaquad means. Cooler fuel means better fuel mileage. Cooler fuel also means "MORE-POWER" AKA "MOPAR". Now the facts can be proven through science. I have them all and pound for pound mama knew whats best?
Re: are thermoquads any good [Re: quickd100] #975727
04/20/11 07:15 PM
04/20/11 07:15 PM
Look closely here are a view tricks. And I have to say that could equal a hole lotta carbs. Specially sence these are the largest carbs that came out on the big three. baby
Re: are thermoquads any good [Re: twinscrew698] #975728
04/20/11 07:22 PM
04/20/11 07:22 PM
Stone Mt, GA.
super gas
super gas
Stone Mt, GA.
Good deal man! That is why I only use ThermoQuads; best in gas mileage and performance and T.Q.'s work on almost any engine!
Re: are thermoquads any good [Re: DEMONSIZZLER] #975729
04/20/11 07:28 PM
04/20/11 07:28 PM
The Demon sizzler?
Re: are thermoquads any good [Re: LikarockCrusher] #975730
04/20/11 07:51 PM
04/20/11 07:51 PM
Stone Mt, GA.
super gas
super gas
Stone Mt, GA.
The Demon sizzler?
No, just a friends hopped-up slant six '73 Space Duster(fold down rear seat). It has an 800 cfm T.Q. I built for the 225 engine.
Here is a pic of my Sizzler pkg A59 Demon:
Re: are thermoquads any good [Re: DEMONSIZZLER] #975731
04/20/11 08:01 PM
04/20/11 08:01 PM
cool
Page 2 of 3 1 2 3
