rear main seal install ? 340/416 #975191
04/17/11 09:12 PM
04/17/11 09:12 PM
USA
K
krw71ragtop Offline OP
K
USA
Had no response in the Q&A section so I'll try here !
Any tips on installing the rear main seal on a 340 ? I'm getting tired of oil leaks. 3rd time fixing this. I can't tell if it's the rear main or the oil pan gasket that's leaking. It drips off the bell housing. Oil sending unit is dry. Can't see the cam plug. The rubber seal on the rear had a tear about a 1/2" at the top right side when I pulled the pan out. The clutch hasn't started slipping yet. would too much oil preasure cause an oil leak ? 90 psi @ start up and about 50 when hot at idle. I know too much preasure will expand the oil filter or blow it apart.
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975192
04/17/11 10:31 PM
04/17/11 10:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a fairly high oil pressure(more than I would
run).... check the crank in the seal area REAL good
I also put a dab of silicone at the edge of the seals
before I place the cap on
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975193
04/17/11 10:43 PM
04/17/11 10:43 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Do you stagger the seals so the each end is inside either the cap or block.........move the parting line a few degrees up or down ?
I have always done this with every other motor I have built and had good luck so far.
This is my first small block MoPar , but I planned on doing this too.
Re: rear main seal install ? 340/416 [Re: tubtar] #975194
04/17/11 10:53 PM
04/17/11 10:53 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Oil pressure should not effect the rear main seal.
Please correct me if I am wrong. Going front to rear. You first have the bearing surface. Then you have the wing that sheds the oil that leaks off the bearing. Then you have the seal.
Crankcase pressure can cause you trouble. I usually coat the outer part of the seal with silicone. Some caps have the little cutouts for the seal with the extra material that extends out under the cap. I have had to cut that material off on my engines. I also have rotated the seal to put the parting line in the cap like mentioned before.
I'm sure someone can chime in as to which engines used the funky cap and seal with the extra material.
Leon
Re: rear main seal install ? 340/416 [Re: Leon441] #975195
04/17/11 11:11 PM
04/17/11 11:11 PM
Eldridge, IA
HR5058 Offline
HR5058  Offline
Eldridge, IA
Had the same problem sometime ago. Staggered the seals and never had a problem again. Chuck
Re: rear main seal install ? 340/416 [Re: MR_P_BODY] #975196
04/17/11 11:17 PM
04/17/11 11:17 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I had the same problem...is there any chance you have a crankcase pressure problem?
Do you run pan-a-vacs in the headers?
My problem , we figure, was the original engine builder put low tension oil rings in ...and that was part of the crankcase pressurization problem.
I'll find out soon, but I had oil puking out of both ends of my oil pan.
Re: rear main seal install ? 340/416 [Re: tubtar] #975197
04/17/11 11:19 PM
04/17/11 11:19 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u can't stagger the rear seal on a sb
Re: rear main seal install ? 340/416 [Re: rickraw] #975198
04/17/11 11:55 PM
04/17/11 11:55 PM
Eldridge, IA
HR5058 Offline
HR5058  Offline
Eldridge, IA
split seals you can. I do it all the time.
Re: rear main seal install ? 340/416 [Re: MR_P_BODY] #975199
04/18/11 12:07 AM
04/18/11 12:07 AM
USA
K
K
USA
I took the oil pump out and removed some of the washers I added to bump up the preasure. I primed it in the vice and now the oil guage reads 75 psi cold with 10 w 30. I usually install main seal with a dab of oil on it and slightly stagger it with 1/2" of the seal sticking out of the block then 1/2" of the seal sticking up on the opposite side of the cap. Then dab the ends with silicone along with the corners of the pan. Maybe the oil on the seal is part of the problem ? And I may have torn the rubber oil pan seal on last install. That was my main concern to use oil or silicone when installing main seal ? Thanks Mr P
Re: rear main seal install ? 340/416 [Re: tubtar] #975200
04/18/11 12:16 AM
04/18/11 12:16 AM
USA
K
K
USA
Yes
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975201
04/18/11 12:20 AM
04/18/11 12:20 AM
kalamazoo, MI.
VIPERDUST Offline
VIPERDUST  Offline
kalamazoo, MI.
I had a builder put that seal in backwards and the oil pushed past the seal.
Re: rear main seal install ? 340/416 [Re: toddd] #975202
04/18/11 12:34 AM
04/18/11 12:34 AM
USA
K
K
USA
I don't think it's a crankcase preasure problem. I use a pcv valve on one side and a 3 line breather on the other. Not sure what a pan-a-vacs is ? But nothing is in the headers.
Re: rear main seal install ? 340/416 [Re: HR5058] #975203
04/18/11 11:11 AM
04/18/11 11:11 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Also,,I silicone behind/back of the seal and put a little on the ends where they meet together in the housings. The oil you are seeing may be going BEHIND the seal and the seal to crank area not be the actual source of the leak.
If you like drag racing, support your local track.
Re: rear main seal install ? 340/416 [Re: CHAPPER] #975204
04/18/11 11:43 AM
04/18/11 11:43 AM
USA
K
K
USA
I think my problem was the rubber oil pan seal. Here is a pucture of how I installed the main seal.
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975205
04/18/11 11:49 AM
04/18/11 11:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Looks like you cut the ends off so you could rotate it, if you did that you should fill those grooves with right-stuff sealant and throw away those little end pieces.
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975206
04/18/11 11:51 AM
04/18/11 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not a fan of rotating the seal... as you see
in the pic you cut the wings off... thats just another
point for a leak... I put a smear of silicone across
the joint and the wings... I've never had a true
main seal leak but have had a pan gasket leak...
alot of us think its a main seal when really it isnt... JMO
Re: rear main seal install ? 340/416 [Re: MR_P_BODY] #975207
04/18/11 12:05 PM
04/18/11 12:05 PM
USA
K
K
USA
I think this was my problem. The last kit I pirchased had the tabs seperate from the main seal. Can't remember what company. I didn't cut them off though. I have the new main seal which are the brown seals in this pic. They are Fel-pro #40181. They came with no tabs on them and no tabs in the box.
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975208
04/18/11 12:39 PM
04/18/11 12:39 PM
USA
K
K
USA
Will the fel-pro black silicone that's in the pic work ok to seal it ?
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975209
04/18/11 12:40 PM
04/18/11 12:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In your case you will have to fill the grooves for
the wings with silicone or Right Stuff but leave a
small mound for a contact point.... the reason I
dont like to rotate the seal is the factory spent
MANY man hours to find a way to cut down the warranty
cost issues with the old style(no wings) and they
came up with the wings.... you never seen a factory
seal rotated..... again... JMO.... I had to replace
the pan on my Jeep(rusted out) and I had to cut the
wings off due to the seal was made backwards and on
a 4.0 engine the wings are different sizes... with
silicone at the joints its bone dry and thats been
over a year and half now
Re: rear main seal install ? 340/416 [Re: krw71ragtop] #975210
04/18/11 12:44 PM
04/18/11 12:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It should but make sure the surfaces are DRY from
any oil(oil the crank so it doesnt stick to it and
tear up the joints)
