rear main seal install ? 340/416
#975191
04/17/11 09:12 PM
04/17/11 09:12 PM
Posts: 892 USA
krw71ragtop
USA
Had no response in the Q&A section so I'll try here ! Any tips on installing the rear main seal on a 340 ? I'm getting tired of oil leaks. 3rd time fixing this. I can't tell if it's the rear main or the oil pan gasket that's leaking. It drips off the bell housing. Oil sending unit is dry. Can't see the cam plug. The rubber seal on the rear had a tear about a 1/2" at the top right side when I pulled the pan out. The clutch hasn't started slipping yet. would too much oil preasure cause an oil leak ? 90 psi @ start up and about 50 when hot at idle. I know too much preasure will expand the oil filter or blow it apart.
Re: rear main seal install ? 340/416
[Re: krw71ragtop]
#975192
04/17/11 10:31 PM
04/17/11 10:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a fairly high oil pressure(more than I would run).... check the crank in the seal area REAL good I also put a dab of silicone at the edge of the seals before I place the cap on
[Re: tubtar]
#975194
04/17/11 10:53 PM
04/17/11 10:53 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Oil pressure should not effect the rear main seal.
Please correct me if I am wrong. Going front to rear. You first have the bearing surface. Then you have the wing that sheds the oil that leaks off the bearing. Then you have the seal.
Crankcase pressure can cause you trouble. I usually coat the outer part of the seal with silicone. Some caps have the little cutouts for the seal with the extra material that extends out under the cap. I have had to cut that material off on my engines. I also have rotated the seal to put the parting line in the cap like mentioned before.
I'm sure someone can chime in as to which engines used the funky cap and seal with the extra material.
Leon
[Re: MR_P_BODY]
#975199
04/18/11 12:07 AM
04/18/11 12:07 AM
Posts: 892 USA
krw71ragtop
USA
I took the oil pump out and removed some of the washers I added to bump up the preasure. I primed it in the vice and now the oil guage reads 75 psi cold with 10 w 30. I usually install main seal with a dab of oil on it and slightly stagger it with 1/2" of the seal sticking out of the block then 1/2" of the seal sticking up on the opposite side of the cap. Then dab the ends with silicone along with the corners of the pan. Maybe the oil on the seal is part of the problem ? And I may have torn the rubber oil pan seal on last install. That was my main concern to use oil or silicone when installing main seal ? Thanks Mr P
[Re: tubtar]
#975200
04/18/11 12:16 AM
04/18/11 12:16 AM
Posts: 892 USA
krw71ragtop
USA
Do you stagger the seals so the each end is inside either the cap or block.........move the parting line a few degrees up or down ? I have always done this with every other motor I have built and had good luck so far. This is my first small block MoPar , but I planned on doing this too.
Yes Thanks
[Re: toddd]
#975202
04/18/11 12:34 AM
04/18/11 12:34 AM
Posts: 892 USA
krw71ragtop
USA
I had the same problem...is there any chance you have a crankcase pressure problem?
Do you run pan-a-vacs in the headers?
My problem , we figure, was the original engine builder put low tension oil rings in ...and that was part of the crankcase pressurization problem.
I'll find out soon, but I had oil puking out of both ends of my oil pan.
I don't think it's a crankcase preasure problem. I use a pcv valve on one side and a 3 line breather on the other. Not sure what a pan-a-vacs is ? But nothing is in the headers.
[Re: CHAPPER]
#975204
04/18/11 11:43 AM
04/18/11 11:43 AM
Posts: 892 USA
krw71ragtop
USA
Had the same problem sometime ago. Staggered the seals and never had a problem again. Chuck
Also,,I silicone behind/back of the seal and put a little on the ends where they meet together in the housings. The oil you are seeing may be going BEHIND the seal and the seal to crank area not be the actual source of the leak.
I think my problem was the rubber oil pan seal. Here is a pucture of how I installed the main seal.
[Re: krw71ragtop]
#975205
04/18/11 11:49 AM
04/18/11 11:49 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Looks like you cut the ends off so you could rotate it, if you did that you should fill those grooves with right-stuff sealant and throw away those little end pieces.
[Re: krw71ragtop]
#975206
04/18/11 11:51 AM
04/18/11 11:51 AM
MR_P_BODY
I'm not a fan of rotating the seal... as you see in the pic you cut the wings off... thats just another point for a leak... I put a smear of silicone across the joint and the wings... I've never had a true main seal leak but have had a pan gasket leak... alot of us think its a main seal when really it isnt... JMO
[Re: krw71ragtop]
#975209
04/18/11 12:40 PM
04/18/11 12:40 PM
MR_P_BODY
I think this was my problem. The last kit I pirchased had the tabs seperate from the main seal. Can't remember what company. I didn't cut them off though. I have the new main seal which are the brown seals in this pic. They are Fel-pro #40181. They came with no tabs on them and no tabs in the box.
In your case you will have to fill the grooves for the wings with silicone or Right Stuff but leave a small mound for a contact point.... the reason I dont like to rotate the seal is the factory spent MANY man hours to find a way to cut down the warranty cost issues with the old style(no wings) and they came up with the wings.... you never seen a factory seal rotated..... again... JMO.... I had to replace the pan on my Jeep(rusted out) and I had to cut the wings off due to the seal was made backwards and on a 4.0 engine the wings are different sizes... with silicone at the joints its bone dry and thats been over a year and half now
[Re: krw71ragtop]
#975210
04/18/11 12:44 PM
04/18/11 12:44 PM
MR_P_BODY
Will the fel-pro black silicone that's in the pic work ok to seal it ?
It should but make sure the surfaces are DRY from any oil(oil the crank so it doesnt stick to it and tear up the joints)
