Recommendations on Carb Restoration #975028
04/17/11 04:18 PM
04/17/11 04:18 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
Looking for some recommendations on having a pair of Hemi carbs redone.
Heard Scott @ Harms and a guy in Manasses VA ( Dick Katter) were both highly capable.
Not looking to have them just kitted, looking to have them restored to corect, original look/function.
Thanks Moparts......
Re: Recommendations on Carb Restoration [Re: zrwhat] #975029
04/17/11 04:39 PM
04/17/11 04:39 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Scott Smith @ Harms is the guy!
Re: Recommendations on Carb Restoration [Re: zrwhat] #975030
04/17/11 04:42 PM
04/17/11 04:42 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
I'd contact Scott Smith first and with one look at his previous restorations, send to him for a professional/expert hemi carb resto.
Re: Recommendations on Carb Restoration [Re: ebodyseast] #975031
04/17/11 06:20 PM
04/17/11 06:20 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
X3 for Scott
Re: Recommendations on Carb Restoration [Re: NV69B7RR] #975032
04/18/11 12:33 AM
04/18/11 12:33 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Some of Scott's fine work!
Re: Recommendations on Carb Restoration [Re: rayztoy] #975033
04/18/11 08:21 AM
04/18/11 08:21 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Scott Smith
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Recommendations on Carb Restoration [Re: MMC Detroit] #975034
04/18/11 09:00 AM
04/18/11 09:00 AM
Well, with what I went through with my AVS with Dick, I think I will be sending it to Scott the next time it needs to be redone!
Re: Recommendations on Carb Restoration [Re: ] #975035
04/18/11 09:17 AM
04/18/11 09:17 AM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
Scott: It'll cost you but you know what you will get.
AAR cuda 71 rag challenger
Re: Recommendations on Carb Restoration [Re: 3406pac] #975036
04/18/11 09:20 AM
04/18/11 09:20 AM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
after 35 years of sitting.
Re: Recommendations on Carb Restoration [Re: 3406pac] #975037
04/18/11 09:24 AM
04/18/11 09:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think you have your pictures mislabeled , or Scott is real good at making them look like they were pulled from a swamp .
Re: Recommendations on Carb Restoration [Re: JohnRR] #975038
04/18/11 09:53 AM
04/18/11 09:53 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hello,
Thanks to all of your supportive comments, I appreciate them and your business!
*John, I don't know if your were serious or not but in case you were, I photograph all carbs I receive right after I unbox them (in detail including part#'s and date codes) before I begin any work, the photos shown are of the same set of carbs "before & after". Nothing was done to enhance either photo.
Re: Recommendations on Carb Restoration [Re: ScottSmith_Harms] #975039
04/18/11 10:30 AM
04/18/11 10:30 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Scott, I think he means that the captions for the "before" and "after" pix are reversed.
Earning every penny of that moderator paycheck.
DBAP
Re: Recommendations on Carb Restoration [Re: not_a_charger] #975040
04/18/11 10:38 AM
04/18/11 10:38 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok
Re: Recommendations on Carb Restoration [Re: ScottSmith_Harms] #975041
04/18/11 11:08 AM
04/18/11 11:08 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Scott, do you test run the carbs?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Recommendations on Carb Restoration [Re: JohnRR] #975042
04/18/11 11:35 AM
04/18/11 11:35 AM
I DA HOE
3
3406pac Offline
3406pac  Offline
I DA HOE
Well maybe I should have added "PRESTO" after 35 years.....
This is what you get.
Someday they will make it on the car.
Maybe we need a PRESTO GRAEMLIN
Re: Recommendations on Carb Restoration [Re: 3406pac] #975043
04/18/11 12:39 PM
04/18/11 12:39 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Scott has done the following carbs for me:
1x 70 198 three speed Carter carb
1x 70 225 three speed Holley carb
1x 71 225 three speed Holley carb
1 set of 70 440+6 auto Holley carbs
1x 70 383+2 Holley carb
3x 70 318 auto Carter carbs
3x 70 318 manual Carter carbs
3x 70 383+4 manual Holley carbs
2x 70 383+4 auto Holley carbs
1x 70 440+4 manual carter carb
2x 71 383+4 manual Holley carbs
3x 70 340 auto Carter carbs
1x 71 383+4 auto Holley carb
1x 71 340 manual Carter carb
1x 71 340 auto Carter carb
2x 71 383+2 Carter carbs
If you want to post pictures of any of them Scott, that would be great! He can work on anything, and always does great work!!
Re: Recommendations on Carb Restoration [Re: ] #975044
04/18/11 01:14 PM
04/18/11 01:14 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Same here! Don't waste your time or money with anyone else.
Scott, you have 3 carbs on the way from me today, just so ya know.
Re: Recommendations on Carb Restoration [Re: Paul Jacobs] #975045
04/18/11 01:38 PM
04/18/11 01:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
A12Bee, yes every carb is test run on a mule engine prior to shipment, it helps a ton in eliminating problems BEFORE they get to the customer
Re: Recommendations on Carb Restoration [Re: ScottSmith_Harms] #975046
04/18/11 02:26 PM
04/18/11 02:26 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Scott, how long can they sit after the rebuild before they are installed, just trying to know what kind of lead time I need so they dont go bad before installation/use.
Re: Recommendations on Carb Restoration [Re: 3406pac] #975047
04/18/11 02:29 PM
04/18/11 02:29 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
I can see the surface of the carbs even though dicromate? plated it looks to have a texture from sandblasting....
...is it possible to have a smoother finish as original?
Maybe the pic is deceiving...I dont know.
