Re: A FEW A/C QUESTIONS?
[Re: 19CHARGER69]
#974872
04/17/11 04:45 PM
04/17/11 04:45 PM
RapidRobert
Might see if you can get the OE pieces from the parts for sale section on here (it'd b cheaper) and what gas are you going to b using. I think an 134 conversion will need a new reciever/drier o rings barrier type hoses diff oil for the compressor diff expansion valve next to the firewall
[Re: 1MYTGTX]
#974874
04/18/11 08:08 AM
04/18/11 08:08 AM
Posts: 21,534 It's a dry heat
gtx6970
It's a dry heat
here are a few detail pictures to help in your quest,,,,,and good luck,,,,your going to need it. Like Chris said, 1969 is one year only for most of the lines and 1 year only for most of the brackets.
[Re: gtx6970]
#974877
04/18/11 08:37 AM
04/18/11 08:37 AM
gtx6970
It's a dry heat
most of the hoses - 'Most' of these are off of a 1969 Charger 383
