440 sixpack carbs #974794
04/17/11 07:00 AM
04/17/11 07:00 AM
Switzerland, Europe
Swiss_Robert Offline OP
Switzerland, Europe
Hi! Last week I was able to fire up my 1970 Challenger 440/sixpack MT clone again after some years of (lazy) work - while the engine was NOT part of that work (but got a new exhaust system from Accurate - if you're interested: http://youtu.be/wU3zEr-ulvI ).
Now I'm dealing with the carbs. They look very worn and my first problem is that I don't get a stable idle. Engine goes up and down at idle and often dies. When I drove the car earlier, cruising or accellerating was not a problem - just idle.
I found https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4572020&Main=4569194 but this just helped half way...
I took the center carb apart and it looks worn inside, too. The shaft in the baseplate has play of about 0,15mm (0,006 inches)which feels like a lot. The choke shaft also has a lot of play and it's outside lever is loose. It has a lot of signs from earlier "human interventions" (like screwdriver marks at jets). It's dirty, throttle flaps got rust ... and so on.
Is such a worn carb worth to rebuild (or "renew" using the appropriate kit)? A new would be about $515 (and they are NEW, from Holley - not "professionally rebuild").
I'm considering just to replace the center carb and leave the outboarders or spend them a rebuild kit. Good idea?
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: 440 sixpack carbs [Re: Swiss_Robert] #974795
04/17/11 10:40 AM
04/17/11 10:40 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
check harms, i think they are a site sponsor
Re: 440 sixpack carbs [Re: Swiss_Robert] #974796
04/17/11 11:10 AM
04/17/11 11:10 AM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
The 6-bbl carbs are tricky to get right...That carb throttle shaft should have teflon seals on each side of the throttle bores...If they're shot or missing completely you'll have a massive vacuum leak from the beginning....But if the shaft and/or bore is wore too hard you're better off with new or sending them out... You can't go wrong using Harms...Scott does excellent work....I guess the ride back and forth from over there would be a factor going the rebuilt route
Re: 440 sixpack carbs [Re: Swiss_Robert] #974797
04/17/11 11:23 AM
04/17/11 11:23 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Your choke issues are normal,the main body,metering block and bowl (unless needle/seat threads are stripped) don't go bad.Some play in the throttle shaft is normal and can be bushed if needed.The biggest problem I have found is bases not square by being over tightened,also an easy fix.From what you describe,I would check for vacuum leaks before I would consider replacing the center carb.If you are using the thin black base gasket and your base is not square,it "will not" seal.I did thirteen 6pk sets last year and six since mid December,very few had based that didn't need milled.
Good luck.
Re: 440 sixpack carbs [Re: screamindriver] #974798
04/17/11 11:55 AM
04/17/11 11:55 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I may be missing something but I have yet to see a production line set of unmolested 6pk carbs with the Teflon seals ever though the shafts are cut to accept them.I've seen them on a lot of 4bbl's,not all and a few over the counter replacements but never an original.
Re: 440 sixpack carbs [Re: 62maxwgn] #974799
04/17/11 05:34 PM
04/17/11 05:34 PM
Switzerland, Europe
Switzerland, Europe
Sounds plausible.
I found quite some leftovers of yellow, crusty material between carb body and manifold-gasket...
Re: 440 sixpack carbs [Re: Swiss_Robert] #974800
04/17/11 05:35 PM
04/17/11 05:35 PM
Switzerland, Europe
Switzerland, Europe
And on the gasket of course...
Re: 440 sixpack carbs [Re: Swiss_Robert] #974801
04/17/11 05:39 PM
04/17/11 05:39 PM
Switzerland, Europe
Switzerland, Europe
Do you recommed to use another, a "thicker" gasket - or only grind it flat?
I tried to make a pic that shows backlight coming thru under my ruler... but it's not to good...
Outboarders will probably leak too, right?
Re: 440 sixpack carbs [Re: Swiss_Robert] #974802
04/17/11 07:11 PM
04/17/11 07:11 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I would machine all three bases and buy a new manifold.
Re: 440 sixpack carbs [Re: 62maxwgn] #974803
04/17/11 09:09 PM
04/17/11 09:09 PM
Harrisburg, Pa.
Harrisburg, Pa.
Guess you did'nt see them all then...
Re: 440 sixpack carbs [Re: screamindriver] #974804
04/17/11 10:31 PM
04/17/11 10:31 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Show me !
Here is another original A12 set,never been apart,I can take another set apart if you wish.You're not that far away,you can even come and watch or I'll meet you half way and we'll do it together!
Re: 440 sixpack carbs [Re: 62maxwgn] #974805
04/17/11 10:32 PM
04/17/11 10:32 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Nor any of these.I would think in 30 + years of doing them I would have found at least one set.
Re: 440 sixpack carbs [Re: 62maxwgn] #974806
04/17/11 11:14 PM
04/17/11 11:14 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I just went out and looked at all mine from nos to nos 82/83 dc carbs, to pos ones, not one seal...can you post a pic or ???
If they can be had id like to get some, one thing I did notice is the very rough (open pits) in the cast base where these would be.
Re: 440 sixpack carbs [Re: quick77rt ] #974807
04/18/11 12:49 AM
04/18/11 12:49 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
These are from old Holley 4bbl parts carbs,never tried to get any,possibly may be able to get from Holley.
Re: 440 sixpack carbs [Re: GomangoCuda] #974808
04/18/11 05:40 AM
04/18/11 05:40 AM
Switzerland, Europe
Switzerland, Europe
I guess I will let machine all three bases, look for a fatter gasket and go with the manifold I have...
And try not to overtighten the attaching screws.
So feel free to quarrel about those seals
But thanks anyway!!!
Re: 440 sixpack carbs [Re: Swiss_Robert] #974809
04/18/11 07:15 AM
04/18/11 07:15 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have taken the base and flattened them by using wet/dry sand papaer wet on a flat surface. I use a thicker gasket with a little sealant, and use very little torque to tighten them down, checking to make sure that the shafts turn freely.
Re: 440 sixpack carbs [Re: BSB67] #974810
04/18/11 07:39 AM
04/18/11 07:39 AM
Switzerland, Europe
Switzerland, Europe
That's at least !
I guess it takes warm-proof sealant? And should be used very thrifty?
Did you cut a thicker gasket yourself?
Re: 440 sixpack carbs [Re: Swiss_Robert] #974811
04/18/11 10:01 AM
04/18/11 10:01 AM
Switzerland, Europe
Switzerland, Europe
Will this gasket , Holley partno 108-52 fit? Onto the sixpack manifold?
Someone tried? Pros'n'cons?
Re: 440 sixpack carbs [Re: Swiss_Robert] #974812
04/18/11 10:21 AM
04/18/11 10:21 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All I've ever used is the original Chrysler fiber/cardboard gasket,1/32" thick,never had a problem.Still available through a dealer,pt.# P4529060,includes three each base and air cleaner gaskets.Also,being that your manifold has been modified,I would remove the center portion of whatever gasket you use to match the intake.
Re: 440 sixpack carbs [Re: Swiss_Robert] #974813
04/18/11 10:34 AM
04/18/11 10:34 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I think they do still sell just the complete lower portion (base) your concerned about and they have the throttle blades already installed. They did a year ago.
I use thick ones like them but without the flap for the carb to base seal and they work well.
In one of my setups I get lucky enough to use 9 gaskets, 6 thin between all the aftermarket plates and the 3 thick ones for the carb to top plate for the good seal and to help keep heat from building up in the carbs.
